Diprotic acids and weak acids/bases
  • Thread starter MathewsMD
  • Tags
    Acids Weak
In summary, the conversation discusses the correct steps for finding the final concentration of HCO3- in an aqueous solution. It also explores the need for recalculation when dealing with equilibrium and how to calculate the final concentration of products and reactants for weak acids and bases. The conversation also introduces the idea of solving a system of equations and the different approaches that can be taken. Finally, it mentions the spontaneous breakdown of carbonic acid in aqueous solution and the additional equilibrium expression it adds to the system.
MathewsMD
433
Hi,
I was reviewing some of my notes and was wondering what the correct steps for this would be (assuming in aqueous solution).
If you have ## H_2CO_3 ⇔ H^+ + HCO_3^- ## finding the final concentration of HCO3- is simple enough.
Now, for ## HCO_3^- ⇔ H^+ + CO_3^{2-} ## this would change the HCO3- concentration and the initial equilibrium from part 1 would have to be recalculated, right? I somewhat understand that this would be a very negligible since Ka values decreases as you go from the diprotic to monoprotic forms. But isn't it necessary to do a recalculation to find the more accurate answer? I find a problem with this...when would we stop recalculating? I understand the effects would be minimal, I'm just having trouble fully verifying this...any clarification would be great!
Also, if you have a weak base and acid, ex. HCO3- again. Although the Ka and Kb values do differ by a few orders of magnitude, how would you calculate the final concentration for the products and reactants of another molecule that has Ka ≈ Kb? Does such a molecule exist?
Sorry for the misguided questions. I am just trying to figure out when we can say a solution is equilibrium since we have all these sub-reactions occurring and it seems there is no point in time where there equilibrium since once you find the equilibrium concentration for one reaction, it changes due to another reaction that the products are a part of. Thanks in advance!
Chemistry news on Phys.org
These relationships only apply to systems in equilibrium. You do not keep recalculating but you solve a system of multiple equations and multiple variables simultaneously, assuming that you can get enough equations written down to allow you to solve for all of the unknowns. This usually involves writing out all of the reactions and their corresponding Keq expressions as well as, typically, mass and charge balance statements.
To throw another wrench in your gears, you should be aware that carbonic acid (H2CO3) spontaneously breaks down to carbon dioxide and water in aqueous solution. This gives another equilibrium expression to consider for such a system.
Go through these three - it is just an introduction, but it shows general approach to more and more complicated pH problems (third page describes diprotic acid, but don't go there without reading the earlier ones):
http://www.chembuddy.com/?left=pH-calculation&right=general-pH-calculation
http://www.chembuddy.com/?left=pH-calculation&right=pH-acid-base-solution
http://www.chembuddy.com/?left=pH-calculation&right=pH-polyprotic-acid-base
(third page assumes acid is dissolved and its total concentration known, as Yanick signaled, in the case of carbonic acid situation is a little bit more complicated).
The approach presented - deriving one equation in one variable (H+) - is not the only one possible. You can also solve system of equations numerically, without any initial preparations, or do some of the steps to convert initial system of equations to an easier to solve one. Which approach works best depends on the problem at hand.
Likes 1 person
Wow, exactly what I was looking for. Thank you!
Hello,
I can understand your confusion and questions regarding diprotic acids and weak acids/bases. Let me try to clarify some of your concerns.
Firstly, for the equilibrium reaction ## H_2CO_3 ⇔ H^+ + HCO_3^- ##, you are correct in saying that finding the final concentration of HCO3- is simple enough. This is because the equilibrium constant (Ka) for this reaction is relatively large, indicating that the reaction favors the formation of products (H^+ and HCO3^-). Therefore, the concentration of HCO3- will be higher than the concentration of H2CO3 in the solution.
Now, for the reaction ## HCO_3^- ⇔ H^+ + CO_3^{2-} ##, you are also correct in saying that this will change the HCO3- concentration and the initial equilibrium from part 1 would have to be recalculated. This is because the equilibrium constant (Ka) for this reaction is smaller than the one for the previous reaction, indicating that the reaction favors the formation of reactants (HCO3^- and CO3^2-). However, as you mentioned, the effect on the HCO3- concentration will be minimal since the Ka values decrease as you go from the diprotic to monoprotic forms. This means that the reaction will not significantly shift the equilibrium and the final concentration of HCO3- will still be higher than the concentration of H2CO3.
To answer your question about when we would stop recalculating, the answer is that it depends on the accuracy and precision needed for your specific experiment or application. In most cases, the effects of the subsequent reactions will be negligible and the initial equilibrium concentrations can be used to determine the final concentrations. However, if a high level of accuracy is required, then the subsequent reactions may need to be taken into account.
Moving on to your question about weak bases and acids, such as HCO3-. In this case, the Ka and Kb values do differ by a few orders of magnitude, indicating that the reaction favors the formation of either H^+ or OH^- depending on the conditions. In such cases, the equilibrium concentrations of the products and reactants can be determined using the Henderson-Hasselbalch equation, which takes into account the Ka and Kb values. And yes, there are molecules that have Ka ≈ Kb, such as water
Related to Diprotic acids and weak acids/bases
1. What is the definition of a diprotic acid?
A diprotic acid is a type of acid that can donate two hydrogen ions (H+) per molecule in an aqueous solution.
2. How does a diprotic acid differ from a monoprotic acid?
A monoprotic acid can only donate one hydrogen ion per molecule, while a diprotic acid can donate two. This means that a diprotic acid has a higher acidity compared to a monoprotic acid.
3. What is the pH of a solution containing a weak acid?
The pH of a solution containing a weak acid will depend on the concentration of the acid and its dissociation constant. Generally, a weak acid will result in a solution with a pH slightly below 7, making it slightly acidic.
4. How do weak acids and bases differ from strong acids and bases?
Weak acids and bases have a lower degree of dissociation in aqueous solution compared to strong acids and bases. This means that they do not completely ionize in water and have a lower concentration of hydrogen ions (for acids) or hydroxide ions (for bases).
5. What are some examples of weak acids and bases?
Some examples of weak acids include acetic acid (found in vinegar), citric acid (found in citrus fruits), and carbonic acid (found in carbonated drinks). Examples of weak bases include ammonia, pyridine, and caffeine.
  • Chemistry
