Dirac Delta and Residue Calculus
In summary, the conversation discusses the similarities between the Dirac delta function and residue calculus, specifically in terms of their integration properties around a singularity or delta. The connection between the two is further explored through the representation of the Heaviside function and its derivative, the delta function. However, understanding of the distributions concept in physical textbooks remains a challenge.
Daniel Gallimore
48
I'm an undergraduate student, so I understand that it may be difficult to provide an answer that I can understand, but I have experience using both the Dirac delta function and residue calculus in a classroom setting, so I'm at least familiar with how they're applied.
Whether you're integrating along a closed loop around a singularity in the complex plane or you're integrating on a closed sphere in 3D space about a Dirac delta (like you might do in E&M), the value of the integral depends entirely on the point where the singularity/delta is located. Do these similarities betray a connection between the Dirac delta and residue calculus?
Well, I would say that there is a closer connection between residues and the Heaviside function [itex]H(x)[/itex] defined as follows:
[itex]H(x) = 0[/itex] if [itex]x < 0[/itex]
[itex]H(x) = 1[/itex] if [itex]x > 0[/itex]
Then an integral representation of [itex]H(x)[/itex] is:
[itex]H(x) = lim_{\epsilon \rightarrow 0} \frac{1}{2\pi i} \int_{-\infty}^{+\infty} \frac{1}{\tau -i \epsilon} e^{ix\tau} d\tau[/itex]
which you can prove using residues.
[itex]H(x)[/itex] is related to the delta-function by formally taking the derivative of this integral representation with respect to [itex]x[/itex]:
[itex]\delta(x) \equiv \frac{dH}{dx} = lim_{\epsilon \rightarrow 0} \frac{1}{2\pi i} \int_{-\infty}^{+\infty} \frac{i \tau}{\tau -i \epsilon} e^{ix\tau} d\tau[/itex]
[itex]= \frac{1}{2\pi} \int_{-\infty}^{+\infty} e^{ix\tau} d\tau[/itex]
It is hard to encounter adequate understanding of the distributions concept in physical textbooks.
Try
KöSaku Yosida. Functional Analysis. Sixth Edition. Springer-Verlag. Berlin Heidelberg New York 1980
stevendaryl said:
is related to the delta-function by formally taking the derivative of this integral representation with respect to xx:
δ(x)≡dHdx=limϵ→012πi∫+∞−∞iττ−iϵeixτdτ\delta(x) \equiv \frac{dH}{dx} = lim_{\epsilon \rightarrow 0} \frac{1}{2\pi i} \int_{-\infty}^{+\infty} \frac{i \tau}{\tau -i \epsilon} e^{ix\tau} d\tau
=12π∫+∞−∞eixτdτ
it just remains to explain what this divergent integral means and in which sense the limit ##\epsilon\to 0## is understood
Related to Dirac Delta and Residue Calculus
1. What is the Dirac Delta function?
The Dirac Delta function, denoted as δ(x), is a mathematical function used to represent a point mass or impulse at a specific location. It is defined as zero everywhere except at x = 0, where it is infinite, and has an area of 1 under its curve.
2. How is the Dirac Delta function used in physics?
The Dirac Delta function is commonly used in physics to represent point charges, point masses, or point vortices. It is also used to describe the behavior of systems in which particles interact instantaneously at a specific point in space.
3. What is residue calculus?
Residue calculus is a mathematical technique used to evaluate complex integrals. It involves using the residues (singularities) of a function in a complex plane to find the value of the integral. It is often used to solve problems in physics, engineering, and various other fields.
4. How is the Dirac Delta function related to residue calculus?
The Dirac Delta function can be represented as a limit of a sequence of functions, known as the approximating functions. These functions have simple poles at the origin, and their residues are equal to 1. This relationship allows for the use of residue calculus to evaluate integrals involving the Dirac Delta function.
5. What are the applications of Dirac Delta and residue calculus in real life?
Dirac Delta and residue calculus have numerous applications in various fields, including signal processing, quantum mechanics, and fluid dynamics. They are used to model and analyze systems with point sources, such as electrical circuits, quantum particles, and fluid flow around a point vortex.
