Dirac Distribution with 2 Diracs
In summary, the conversation discusses the use of Dirac delta functions in distribution integrals and how they can be expressed in a compact form, specifically in the case of multiple variables. The summary includes the known properties of Dirac delta functions and provides an example of a multi-dimensional version of the integral.
divB
87
Hi,
It is well known that
[itex]
\int f(x) \delta(x-a) dx = f(a) \quad\mathrm{and}\\
\int f(x) \delta^{(n)}(x-a) dx = (-1)^n f^{(n)}(a)
[/itex]
Similarly, Is there a way to express a distribution integral with multiplicative Diracs in a compact form (e.g., a sum)?
[itex]
\int f(x) \delta(t-x-l_1) \delta(t-x-l_2) dx
[/itex]
Thanks,
divB
The way you have written this, with a single x, is a bit misleading. What you show would be simply f(t- l) if [itex]l_1= l_2= l[/itex] and 0 if [itex]l_1\ne l_2[/itex].
But I suspect you mean a multi-dimensional version where x, t, and l are all vectors or shorthand for multiple variables. In that case,
[tex]\int\int f(x,y)\delta(t_x- x- l_1)\delta(t_y- y- l_2)dxdy= f(t_x-l_1, t_y- l_2)[/tex]
Thank you, your answer was exactly what I was looking for!
FAQ: Dirac Distribution with 2 Diracs
What is the Dirac Distribution with 2 Diracs?
The Dirac Distribution with 2 Diracs is a mathematical concept used to describe the behavior of point particles in physics. It is a type of probability distribution function that assigns a value of infinity at a specific point and zero everywhere else.
How is the Dirac Distribution with 2 Diracs different from the standard Dirac Distribution?
The standard Dirac Distribution only has one Dirac delta function, while the Dirac Distribution with 2 Diracs has two delta functions. This means that the probability of finding a particle at two specific points, represented by the two delta functions, is greater than the probability of finding it at any other point.
What is the significance of the Dirac Distribution with 2 Diracs in physics?
The Dirac Distribution with 2 Diracs is often used in quantum mechanics to describe the behavior of particles with definite positions and momentums. It also has applications in signal processing and electrical engineering.
Can the Dirac Distribution with 2 Diracs be visualized?
No, the Dirac Distribution with 2 Diracs cannot be visualized as it represents an infinitesimally small point in space with infinite probability. However, it can be represented graphically as two delta functions at specific points on a graph.
Is the Dirac Distribution with 2 Diracs a physically realizable concept?
No, the Dirac Distribution with 2 Diracs is a theoretical concept used in mathematical models. It cannot be physically realized as it represents a point with infinite probability, which is not possible in the physical world.
