Dirac eq gamma matrices question
In summary, the Dirac spinors and gamma matrices can be used to construct different types of quantities, such as pseudoscalars and vectors. The proofs for these results can be found in books on symmetries and supersymmetries. Gamma-5 and gamma-mu are different matrices, but they represent different things in the Dirac algebra. The transformation properties of these covariants are determined by their commutators with Σμν. Under parity transformation, gamma-5 has a pseudoscalar character while gamma-mu has a vector character.
copernicus1
99
In almost all the books on field theory I've seen, the authors list out the different types of quantities you can construct from the Dirac spinors and the gamma matrices, but I'm confused by how these work. For instance, if $$\overline\psi\gamma^5\psi$$ is a pseudoscalar, how can $$\overline\psi\gamma^\mu\psi$$ be a vector? Aren't gamma-5 and gamma-mu just different matrices? How do you get a vector out of the second operation?
Thanks!
Have you seen proofs for these 2 results ? It's true that most books gloss over these things without the explicit calculations. I vaguely remember that the proofs for all the so-called <Dirac bilinears> are in Müller-Kirsten and Wiedemann's book on symmetries and supersymmetries. They contain about 100+ pages of calculations with spinors in 4D.
Gamma-5 and gamma-mu are indeed all matrices, BUT the four different gamma-mu represent the Dirac algebra, whereas gamma-5 is not an element of that representation - so that's where the difference must come in.
(If your question is about the number of components and the fact that really gamma-mu is just a single matrix, then what the authors mean is that the second quantity transforms as a *component* of a four-vector.)
In addition to transforming the spacetime coordinates, the Lorentz transformation also transforms the spinor components: ψ → Λψ, where Λ is a 4 x 4 matrix. For an infinitesimal transformation, Λ = I + ½εμνΣμν where Σμν = ½γμγν. It's their commutators with Σμν that determine the transformation properties of the Dirac covariants. For example, γμ → Λ-1γμΛ = γ'μ.
For that you will have to learn how dirac spinors transform under parity.Under parity transformation
ψ-γ5ψ(x,t)-ψ-γ0γ5γ0ψ(-x,t)=-ψ-γ5ψ(-x,t)
which shows that it has a pseudoscalar character.while ψ-γμψ is a lorentz vector which means
ψ-γμψ-Λμvψ--1x)γvψ(Λ-1x)
Related to Dirac eq gamma matrices question
1. What is the Dirac equation?
The Dirac equation is a relativistic quantum field equation that describes the behavior of fermions, such as electrons, in terms of wave functions. It was developed by British physicist Paul Dirac in 1928.
2. What are gamma matrices?
Gamma matrices are a set of mathematical objects that are used in the Dirac equation to represent the spinor nature of fermions. They are 4x4 matrices that satisfy a set of algebraic relationships.
3. How do gamma matrices relate to the Dirac equation?
The gamma matrices are used in the Dirac equation to represent the spin and momentum of fermions. They are multiplied with the wave function to obtain the correct solutions for the equation.
4. What is the significance of the gamma matrices in physics?
The gamma matrices are important in physics because they allow us to describe the behavior of fermions, such as electrons, in a relativistic framework. They also play a role in the Standard Model of particle physics.
5. Are there any real-world applications of the Dirac equation and gamma matrices?
Yes, the Dirac equation and gamma matrices have many applications in physics, including in the study of quantum mechanics, particle physics, and materials science. They have also been used in developing quantum computers and in understanding the behavior of electrons in condensed matter systems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
