- #36
newbee
- 80
As far as I can tell they are not more or less the same but simply the same.Fredrik said:The mathematical definition of a coordinate system is more or less the same in all of those theories,
I think we are or I am talking about both.Fredrik said:but we're not talking about points in the mathematical model of space. We're talking about measurements,
I would not disagree with that statement.Fredrik said:so you're going to have to use two physical objects to define two positions in space before you even try to measure the distance between them.
I disagree with this line of reasoning. You have already "you're going to have to use two physical objects to define two positions". If you can do that much then you need no more. The theory about the objects behavior adds nothing. You have already presumed that the objects "define" two positions.Fredrik said:The behavior of those physical objects is independent of all theories (in the sense that they are going to behave in a certain way no matter what theories humans are able to come up with), but if you're going to measure the distance between them, you're going to have to make assumptions about how they behave,
