MHB Direct Products of Modules .... Bland Proposition 2.1.1 .... ....
  • Thread starter Thread starter Math Amateur
    Modules
The discussion centers on understanding the proof of Proposition 2.1.1 from Paul E. Bland's "Rings and Their Modules," specifically regarding the necessity of the mappings being R-linear. The proposition states that for every R-module N and family of R-linear mappings, there exists a unique R-linear mapping f to the product of the modules. Participants clarify that to prove f is R-linear, one must demonstrate that it satisfies the properties of R-linearity using the definitions and relationships established in the proof, particularly the projection mappings. The conclusion emphasizes that the R-linearity of the individual mappings fα is crucial for establishing the R-linearity of the mapping f. Understanding these relationships is essential for completing the proof effectively.
Math Amateur
MHB
I am reading Paul E. Bland's book: Rings and Their Modules and am currently focused on Section 2.1 Direct Products and Direct Sums ... ...
I need help with some aspects of the proof of Proposition 2.1.1 ...
Proposition 2.1.1 and its proof read as follows:
In the statement of the above proposition we read the following:
" ... ... for every $$R$$-module $$N$$ and every family $$\{ f_\alpha \ : \ N \rightarrow M_\alpha \}_\Delta$$ of $$R$$-linear mappings there is a unique $$R$$-linear mapping $$f \ : \ N \rightarrow \prod_\Delta M_\alpha$$ ... ... "The proposition declares the family of mappings $$\{ f_\alpha \ : \ N \rightarrow M_\alpha \}_\Delta$$ as $$R$$-linear mappings and also declares that $$f$$ (see below for definition of $$f$$!) is an $$R$$-linear mapping ...
... BUT ...
I cannot see where in the proof the fact that they are $$R$$-linear mappings is used ...
Can someone please explain where in the proof the fact that the family of mappings $$\{ f_\alpha \ : \ N \rightarrow M_\alpha \}_\Delta$$ and $$f$$ are $$R$$-linear mappings is used ... basically ... why do these mappings have to be $$R$$-linear ... ?
Help will be much appreciated ...
Peter======================================================================================The above post mentions but does not define $$f$$ ... Bland's definition of $$f$$ is as follows:
View attachment 8031Hope that helps ...
Peter***EDIT***
In respect of $$f$$ it seems we have to prove $$f$$ is an $$R$$-linear mapping ... but then ... where is this done ...
Bland defines the map $f:N \longrightarrow \prod_\Delta M_\alpha$ by saying that $f$ is product of the family of mappings $f_\alpha:N \longrightarrow M_\alpha$. YOU have to fill in the proof that $f$ is an R-linear map, by using the fact that $f_\alpha$ is a R-linear maps for all $\alpha \in \Delta$.
The mappings $f_\alpha:N \longrightarrow M_\alpha$ have to be R-maps, because $f$ has to become an R-map and because $\pi_\alpha \circ f = f_\alpha$ for all α∈Δ.
Hi Steenis ... thanks for your help ...
You write:
" ... ... YOU have to fill in the proof that $f$ is an R-linear map, by using the fact that $f_\alpha$ is a R-linear maps for all $\alpha \in \Delta$. ... ... "
Yes ... of course you're right ...
BUT ... need some help ...We need to show $$f$$ is an $$R$$-linear map (homomorphism) ...
We are given that the $$f_\alpha$$ are $$R$$-linear maps, and we know that the projections $$\pi_\alpha$$ are $$R$$-linear maps ...
We also know that $$\pi_\alpha f = f_\alpha$$ for each $$\alpha \in \Delta$$ ... ... ... ... ... (1)
Now ... we know that if $$f$$ is an $$R$$-linear mapping then (1) holds true but ...
... how do you prove that f must necessarily be an $$R$$-linear map ... ...... can you help ... ... ?
Peter
To show that $f:N \longrightarrow \prod_\Delta M_\alpha$ is an R-linear map, use the definition of R-linear map. So you have to show that:
$f(x+y) = f(x) + f(y)$ for $x, y \in N$ and
$f(xr) = f(x)r$ for $x \in N$ and $r \in R$ (in case of a right R-module).
$f$ is defined as the product of the family of mappings $f_\alpha:N \longrightarrow M_\alpha$. So $f(x)=(f_\alpha(x))_{\alpha \in \Delta}$ and $f(y)=(f_\alpha(y))_{\alpha \in \Delta}$ for $x, y \in N$ by definition.
Thus $f(x+y) = (f_\alpha(x+y))=(f_\alpha(x)+f_\alpha(y))=(f_\alpha(x))+(f_\alpha(y))=f(x)+f(y)$.
You can do the second part.
I am sorry, Peter, did NOT ask me to prove that $f$ is R-linear, you DID ask me why $f$ is necessarily R-linear, given that $\pi_\alpha \circ f = f_\alpha$ in which $\pi_\alpha$ and $f_\alpha$ are R-linear.
I think this is why, take $x, y \in N$ then $\pi_\alpha f(x+y) = \pi_\alpha (f_\alpha(x+y)) = f_\alpha(x+y) = f_\alpha(x) + f_\alpha(y)$.
From this it follows $(f_\alpha(x+y)) = (f_\alpha(x)) + (f_\alpha(y))$ and $f(x+y)=f(x)+f(y)$. (you can do the second rule).
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
