Direct Products of Modules .... Bland Proposition 2.1.1 ....
  • I
  • Thread starter Math Amateur
  • Tags
    Modules
In summary, a direct product of modules is a mathematical concept that combines two or more modules to create a new module containing all possible combinations of elements from the original modules. It differs from a direct sum in that it preserves the individual structures of the original modules. Bland Proposition 2.1.1 states that direct products of modules are commutative and associative, making them useful in simplifying computations and proofs. They have various real-world applications but are limited to modules with the same underlying structure and must be finite.
Math Amateur
MHB
3,998
48
I am reading Paul E. Bland's book: Rings and Their Modules and am currently focused on Section 2.1 Direct Products and Direct Sums ... ...
I need help with some aspects of the proof of Proposition 2.1.1 ...
Proposition 2.1.1 and its proof read as follows:
In the statement of the above proposition we read the following:
" ... ... for every ##R##-module ##N## and every family ##\{ f_\alpha \ : \ N \rightarrow M_\alpha \}_\Delta## of ##R##-linear mappings there is a unique ##R##-linear mapping ##f \ : \ N \rightarrow \prod_\Delta M_\alpha## ... ... "The proposition declares the family of mappings ##\{ f_\alpha \ : \ N \rightarrow M_\alpha \}_\Delta## as ##R##-linear mappings and also declares that ##f## (see below for definition of ##f##!) is an ##R##-linear mapping ...
... BUT ...
I cannot see where in the proof the fact that they are ##R##-linear mappings is used ...
Can someone please explain where in the proof the fact that the family of mappings ##\{ f_\alpha \ : \ N \rightarrow M_\alpha \}_\Delta## and ##f## are R-linear mappings is used ... basically ... why do these mappings have to be ##R##-linear (that is, homomorphisms...) ... ?
Help will be much appreciated ...
Peter======================================================================================The above post mentions but does not define ##f## ... Bland's definition of ##f## is as follows:
Hope that helps ...
Peter***EDIT***
In respect of ##f## it seems we have to prove ##f## is an ##R##-linear mapping ... but then ... where is this done ...
Math Amateur said:
I cannot see where in the proof the fact that they are ##R-##linear mappings is used ...
Have you tried to prove that ##f## is ##R-##linear without using this property of the ##f_\alpha\,?## It is part of the set up, as we consider ##R-##modules, and thus the morphisms in this category have to be ##R-##linear. The linearity of the ##f_\alpha## extend to the linearity of ##f##, a property (of ##f\,##) which isn't used, but has to be shown (in order to stay in the category). But you will need the linearity of the ##f_\alpha## but these are given.
Likes Math Amateur
Thanks fresh_42
Appreciate your help ...
Peter
Hi fresh_42 ...
... have tried the following ..
We need to show ##f## is an ##R##-linear map (homomorphism) ...
We are given that the ##f_\alpha## are ##R##-linear maps, and we know that the projections ##\pi_\alpha## are ##R##-linear maps ...
We also know that ##\pi_\alpha f = f_\alpha## for each ##\alpha \in \Delta## ... ... ... ... ... (1)
Now ... we know that if ##f## is an ##R##-linear mapping then (1) holds true but ...
... how do you prove that f must necessarily be an ##R##-linear map ... ...... can you help ... ... ?
Peter
Just write down the definition: ##f(r\cdot x + s \cdot y) = \ldots ## with ##x=(x_\alpha)\; , \;y=(y_\alpha)## and ##f = \Pi_\alpha f_\alpha## and use the ##R-##linearity of all ##f_\alpha##.
Likes Math Amateur
Related to Direct Products of Modules .... Bland Proposition 2.1.1 ....
1. What is a direct product of modules?
A direct product of modules is a mathematical concept that involves combining two or more modules (which are structures used to study abstract algebraic objects) to create a new module. This new module contains all possible combinations of elements from the original modules.
2. How is a direct product of modules different from a direct sum?
While a direct product and a direct sum may seem similar, they have different properties. A direct product preserves the individual structures of the original modules, while a direct sum combines the structures into a new, larger structure.
3. What is the significance of Bland Proposition 2.1.1 in the context of direct products of modules?
Bland Proposition 2.1.1 is a theorem that states that the direct product of modules is commutative and associative, meaning the order in which the modules are combined does not affect the result. This property is important in simplifying computations and proofs involving direct products.
4. Can direct products of modules be applied to real-world problems?
Yes, direct products of modules have many practical applications in fields such as engineering, computer science, and physics. For example, they are used in coding theory and signal processing to represent and manipulate complex data structures.
5. Are there any limitations or restrictions when using direct products of modules?
Yes, there are certain restrictions when using direct products of modules. For example, the modules being combined must have the same underlying structure, such as being vector spaces over the same field. Additionally, the modules must be finite in order for the direct product to be well-defined.
  • Linear and Abstract Algebra
