Direct Products of Modules .... Canonical Injections ....
  • I
  • Thread starter Math Amateur
  • Tags
    Modules
In summary: A## for all ##a \in A## ... so ##g \circ f = i_A## is an injective function ... and since ##g## is injective, it is surjective ... so ##f## has a left inverse ##\Longleftrightarrow f## is injective
Math Amateur
MHB
3,998
48
I am reading Paul E. Bland's book: Rings and Their Modules and am currently focused on Section 2.1 Direct Products and Direct Sums ... ...
I need help with some aspects of the proof of Proposition 2.1.4 ...
Proposition 2.1.4 and its proof read as follows:
In the above proof by Paul Bland we read the following:
" ... ... Since ##p_\alpha u_\alpha = \text{ id}_{ M_\alpha }##, we have that ##u_\alpha## is an injective mapping and that ##p_\alpha## is surjective ... ... "Can someone please explain exactly how/why ##u_\alpha## is an injective mapping ... ?Help will be appreciated ...
Peter
A mapping is injective if and only if there exists a left inverse for the map. Here, the left inverse is given by ##p_\alpha##.
Also, a mapping is surjective if there exists a right inverse for the map.
As a side note, the converse implication for this last statement also holds, if and only if the axiom of choice is true, but you won't need it here.
Can you prove these 2 claims?
Likes Math Amateur
Hi Math_QED ...
Note the following:
Given ##f \ : \ A \longrightarrow B##, we say that a function ##g \ : \ B \longrightarrow A## is a left inverse for ##f## if ##g \circ f = i_A##
Will try to prove the following:
##f## has a left inverse ##\Longleftrightarrow f## is injective Now assume ##f## has a left inverse, say, ##g## ...
Let ##f(a) = f(b)## ... ... need to show ##a = b## ...
Now ##g \circ f (a) = g( f(a) ) = i_A (a) = a## ... ... ... ... ... (1)
and ##g \circ f (b) = g( f(b) ) = i_A (b) = b## ... ... ... ... ... (2)But since ##f(a) = f(b)## ...
... we have that (2) ##\Longrightarrow g \circ f (b) = b = g( f(b) ) = g( f(a) ) = i_A (a) = a##
... so ##a =b## ... ...
Is that correct ...?
NOTE ... now need to show that ##f## is injective ##\Longrightarrow f## has a left inverse ...
BUT ... not making any meaningful progress ... can you help ...?
Peter
Math Amateur said:
Hi Math_QED ...
Note the following:
##f## has a left inverse ##\Longleftrightarrow f## is injectiveNow assume ##f## has a left inverse, say, ##g## ...
Peter
Your first proof is correct. Well done!
The other direction is not necessary in the proof you are working on, and it is the harder one. But it is an intersting and basic theorem anyway.
We have to actually construct a left inverse for ##f##, and once you have seen the trick, you will be able to apply it to similar problems.
So, our goal is to make a function ##g: B \to A## that 'undoes' ##f## from the left.
How can we map an element ##b \in B## to an element in ##a \in A## in a manner that has something to do with ##f##?
Hint: ##f(A) \subseteq B##
Likes Math Amateur
That direction is not necessary in the proof, and it is the harder one. But it is an intersting and basic theorem anyway.
Given ##f \ : \ A \longrightarrow B## is injective ... we want to show that ##f## has a left inverse function, say ##g## ...
Define ##g## this way ... where ##f(a) = b## for ##a \in A, b \in B## ... define ##g## such that ##g \ : \ B \longrightarrow A## where ##g(b) = a## ...
... so that ##g \circ f (a) = g(f(a) ) = a## ...
The above definition is possible because ##f## is injective ...
Defining ##g## in the above way for each ##a \in A, b \in B## where ##f(a) = b## means ##g## is the left inverse of ##f## ...Is that correct?
Peter
Peter
The idea is correct, but your function is not defined on ##B## but rather on ##f(A)##. What if ##f## is not surjective? Then some ##b##'s won't be attained by ##f##.
Just this needs fixing. Can you think of a way to give an image to ##b \notin f(A)##?
You noted correctly that injectivity is required to make the function ##g## well-defined.
Likes Math Amateur
Hmm ... can see the problem ...
But cannot see the answer to the problem ...
Peter
Peter
In the end, you want that for ##a \in A##,
##g \circ f(a) = g(f(a)) = a##
So, for this condition to be true, it doesn't matter how ##g## is defined outside ##f(A)##.
Can you have another attempt now?
Well ... if how ##g## is defined outside ##f(A)## just put ##g(b) = 0## or simply ##g(b)## = arbitrary element of ##A## if ##0## is not an element of ##A## ... and do this for all ##b## outside ##f(A)## ...
Would that do ...?
Peter
Would that do ...?
Peter
Well, an arbitrary fixed element indeed works!
Likes Math Amateur
Thanks Math_QED ... really appreciate your help...
Peter
Likes member 587159
I agree with everything here. But I would like to remark that the situation here, as QED well knows, is a little more subtle. In this proof the left inverse that is given is also linear. In fact an injective linear map, although it has a left inverse function, need not have one that is linear. So since this injective linear map has a linear left inverse, it is a little more special than just any old injective linear map. E.g. the injection of the even integers into the group of all integers, is injective and linear, but has no linear left inverse. Just didn't want the OP to come away with a possible wrong impression, but maybe no need to worry.
Likes Math Amateur
Thanks mathwonk ... appreciate your help, guidance and support...
Peter
Related to Direct Products of Modules .... Canonical Injections ....
1. What is a direct product of modules?
A direct product of modules is a way of combining two or more modules into a new module. It is denoted as M1 x M2 x ... x Mn and consists of all possible combinations of elements from each individual module.
2. How are direct products of modules related to Cartesian products?
Direct products of modules are closely related to Cartesian products, as they share similar properties such as closure under addition and multiplication. However, direct products of modules are specifically defined for modules, whereas Cartesian products can be applied to any set.
3. What are canonical injections in the context of direct products of modules?
Canonical injections are homomorphisms that map elements from each individual module to their corresponding element in the direct product. They are often used to define the structure and operations of the direct product.
4. How are direct products of modules useful in mathematics?
Direct products of modules are useful in mathematics for studying the structure and properties of larger modules. They allow us to break down complex modules into simpler ones and analyze them separately.
5. Can direct products of modules be applied to non-commutative modules?
Yes, direct products of modules can be applied to both commutative and non-commutative modules. However, the resulting direct product may exhibit different properties depending on the commutativity of the individual modules involved.
  • Linear and Abstract Algebra
