Direct steam injection into cooling water line at pump suction
In summary, using steam injection to get hot water at a higher temperature can damage the pump and seals. You should use a closed loop heat exchanger if possible.
tinakaran26
TL;DR Summary
Currently there is an operation scenario at one of our plant which directly injecting steam into cooling water line at pump suction in order to generate hot water at 60 deg C for circulation, by doing this its generate vapor at pump suction and lead to cavitation which ultimately damage pump and mechanical seals. Please advise better solution to this rather than installing a heat exchanger.
Setting aside why you would want to heat up cooling water, you could inject the steam after the pump or use a closed loop heat exchanger.
Likes hmmm27
DearRuss
Thank you for the reply. There is another latest update, i have find out there is condensate tank nearby which most of condensate being send to drain. If i replace the steam injection with this condensate from condensate tank at pump suction to get hot water at 60 deg c, is that it will solve the problem since there will be no steam bubble? or still need to relocate the injection point to pump discharge?
Whenever pumping hot water, or any liquid with high vapor pressure, you need to check the NPSH (Net Positive Suction Head) of the pump. Good search terms to learn about NPSH are pump npsh. Also, study the manufacturer's website and pump catalog for your pump. There will be information about NPSH in there.
NPSH is easy to deal with when pumping condensate because it is only necessary to make sure the pump suction is a sufficient distance below the liquid level. It's more difficult when using steam injection at the pump inlet because the steam must be both fully condensed and fully mixed before entering the pump suction in order to prevent cavitation.
It is better to send condensate back to the boiler than to use it as hot water elsewhere. It is better to use condensate as hot water elsewhere than to send it down the drain. Almost anything is better than sending condensate down the drain.
Likes JBA and anorlunda
Related to Direct steam injection into cooling water line at pump suction
1. What is direct steam injection into cooling water line at pump suction?
Direct steam injection into cooling water line at pump suction is a process in which steam is injected directly into the cooling water line at the suction of a pump. This is done to increase the temperature of the cooling water, which in turn increases the efficiency of the pump.
2. Why is direct steam injection into cooling water line at pump suction necessary?
This process is necessary because it helps to maintain a consistent temperature in the cooling water, which is crucial for the proper functioning of the pump. It also helps to prevent the cooling water from freezing in cold weather conditions.
3. How does direct steam injection into cooling water line at pump suction work?
The steam is injected into the cooling water line at the suction of the pump using a nozzle or diffuser. The steam mixes with the cooling water, raising its temperature. The heated water then flows into the pump, increasing its efficiency and preventing any potential damage from cold water.
4. What are the benefits of direct steam injection into cooling water line at pump suction?
There are several benefits to this process, including increased pump efficiency, prevention of freezing in cold weather, and protection against thermal shock. It also helps to reduce energy consumption and operating costs.
5. Are there any safety concerns with direct steam injection into cooling water line at pump suction?
Yes, there are some safety concerns that need to be taken into consideration when using this process. It is important to ensure that the steam is injected at the correct pressure and temperature to prevent any potential hazards. It is also important to have proper safety measures in place, such as pressure relief valves, to prevent over-pressurization of the system.
  • Mechanical Engineering
