Direct Sums of Copies of Modules - B&K - Exercise 2.1.6 (iii)
In summary, the conversation is about Exercise 2.1.6 in Chapter 2 of the book "An Introduction to Rings and Modules With K-Theory in View" by A.J. Berrick and M.E. Keating. The exercise involves interpreting the notation M_k ( \text{End} (L) ) and using induction to solve the problem. The conversation also includes a discussion on idempotents and the full set of inclusions and projections. The concept of block matrices is also mentioned.
Math Amateur
MHB
3,998
48
I am reading An Introduction to Rings and Modules With K-Theory in View by A.J. Berrick and M.E. Keating (B&K).
In Chapter2: Direct Sums and Short Exact Sequences we find Exercise 2.1.6 part (iii). I need some help to get started on this exercise.
Exercise 2.1.6 reads as follows:View attachment 3365
I am attempting to get started on part (iii) but need help.
In particular, could someone help me interpret \(\displaystyle M_k ( \text{End} (L) ) \) ... what entity is this? Looks like a matrix (or module?) multiplied by \(\displaystyle \text{End} (L) \) written as a matrix?
Are we to assume that as well as \(\displaystyle M\) being equal to \(\displaystyle L^{\Lambda}\) we also have that
\(\displaystyle M = M_1 \oplus M_2 \oplus M_3 \oplus \ ... \ ... \ \oplus M_k \oplus \ ... \ ... \ \oplus M_n\)
... ... and that \(\displaystyle M_k\) is the \(\displaystyle k\)th element of the direct sum written as a matrix?
Can someone please help clarify the notation and also get me started on the exercise.
Peter
***NOTE***
The exercise mentions idempotents as well as the full set of inclusions and projections. Thus, to ensure that MHB members can appreciate the context of the above post I am providing the relevant text on these topics from B&K.
The relevant text from B&K on standard inclusions and projects is as follows:View attachment 3367
https://www.physicsforums.com/attachments/3368
The relevant text from B&K on idempotents is as follows:
https://www.physicsforums.com/attachments/3369
https://www.physicsforums.com/attachments/3370
To do (iii) I suggest tackling the $k = 2$ case, first, and applying the results of (i).
Can you think of a way to use induction on $k$ and the fact that:
$L^k \cong L^{k-1} \oplus L$?
(in other words, direct sums are associative "up to isomorphism").
The matrices detailed in this exercise are often called "block matrices", in which matrix "blocks" are treated as if they were matrix "entries" (this makes sense as long as the blocks are of "matching sizes" for the requisite multiplication).
Thanks, I will try that ... BUT ... can you please clarify the meaning of \(\displaystyle M_k ( \text{End} (L) ) \) ... ...
Thanks again,
Peter
Thanks again,
Peter
I'm not familiar with your text, but it should be the same as $M_n(R)$ where instead of ring-elements of $R$, the matrix entries are endomorphisms of $L$. These, after all, DO form a ring.
OK ... BUT ... just to confirm ... the answer to my question in the previous post, then ...
" ... ... Are we to assume that as well as \(\displaystyle M\) being equal to \(\displaystyle L^{\Lambda}\) we also have that
... ... and that \(\displaystyle M_k\) is the \(\displaystyle k\)th element of the direct sum written as a matrix? ... ... "
Is yes ... ... ?
For some reason it just bothered me that both conditions were on M ... ... Peter
Hi Peter,
The set $M_k(\text{End } L)$ consists of all $k \times k$ matrices with entries in $\text{End } L$. Given $f \in \text{End}(L^k)$, define a matrix $(f_{ij}) \in M_k(\text{End } L)$ by setting $f_{ij} = \pi_i f\sigma_j$, for $1 \le i, j \le k$. This yields a map $T : \text{End}(L^k) \to M_k(\text{End } L)$, which you can show is an $R$-homomorphism. Conversely, given $f_{ij} \in M_k(\text{End } L)$, define an element $f\in \text{End}(L^k)$ by setting
\(\displaystyle f(x_1,\ldots, x_k) = \sum_{j = 1}^k (f_{1j}(x_j),\ldots, f_{kj}(x_j))\)
for all $(x_1,\ldots, x_k)\in L^k$. In other words,
\(\displaystyle f = \sum_{i, j = 1}^k \sigma_i f_{ij} \pi_j.\)
This determines a map $S : M_k(\text{End } L) \to \text{End}(L^k)$. For all $f \in \text{End}(L^k)$,
\(\displaystyle ST(f) = S((\pi_if\sigma_j)) = \sum_{i, j = 1}^k \sigma_i \pi_i f\sigma_j\pi_j = \sum_{j =1}^k f\sigma_j\pi_j = f\)
Thus $ST = id_{\text{End}(L^k)}$. For all $(f_{ij})\in M_k(\text{End } L)$,
\(\displaystyle TS(f_{ij}) = T\Bigl(\sum_{\ell, m = 1}^k \sigma_\ell f_{\ell m}\pi_m\Bigr) = \Bigl(\pi_i\Bigl(\sum_{\ell, m = 1}^k \sigma_\ell f_{\ell m}\pi_m\Bigr)\sigma_j\Bigr) \)
\(\displaystyle = \sum_{\ell,m = 1}^k (\pi_i\sigma_{\ell}f_{\ell m}\pi_m\sigma_j) = \sum_{\ell,m = 1}^k (\delta_{i\ell}f_{\ell m}\delta_{mj}) = (f_{ij})\)
Therefore, $TS = id_{M_k(\text{End } L)}$. This shows that $T$ is a one-to-one correspondence. Since $T$ is also an $R$-homomorphism, it is an isomorphism of $\text{End}(L^k)$ onto $M_k(\text{End } L)$.
I don't understand your second question. What is $L^\Lambda$ and what do you mean when you say "$M_k$ is the $k$th element of the direct sum written as a matrix"?
Euge said:
Hi Peter,
Thanks Euge, I think you have answered my question ...
You write:
" ... ... I don't understand your second question. What is $L^\Lambda$ and what do you mean when you say "$M_k$ is the $k$th element of the direct sum written as a matrix"? ... ..."
The notation you ask about comes from B&K as follows:
https://www.physicsforums.com/attachments/3374
https://www.physicsforums.com/attachments/3375Just working through the details of your post now ...
Thanks again for your help ...
Peter
Is yes ... ... ?
I see no reason to suppose the $k$ in $M_k(\text{End}(L))$ refers to some summand of a direct sum. But, because of possible confusion like this, I prefer the notation:
$\text{Mat}_k(R)$ which is less ambiguous.
FAQ: Direct Sums of Copies of Modules - B&K - Exercise 2.1.6 (iii)
What is a direct sum of copies of modules?
A direct sum of copies of modules is a type of module that is constructed by combining smaller modules together. It is denoted as M ≅ M1 ⊕ M2 ⊕ ... ⊕ Mn, where M1, M2, ..., Mn are submodules of M.
How is a direct sum of copies of modules different from a direct product?
A direct sum of copies of modules is different from a direct product in that the elements of a direct sum are finite linear combinations of elements from the submodules, whereas the elements of a direct product are infinite tuples of elements from the submodules.
What is the importance of studying direct sums of copies of modules?
Direct sums of copies of modules are important in understanding the structure of modules and their submodules. They also have applications in linear algebra, representation theory, and algebraic geometry.
Can direct sums of copies of modules have an infinite number of submodules?
Yes, direct sums of copies of modules can have an infinite number of submodules. This is because the submodules can be chosen from any set, including infinite sets.
How do you determine the dimension of a direct sum of copies of modules?
The dimension of a direct sum of copies of modules is equal to the sum of the dimensions of its submodules. This is because the elements of a direct sum are finite linear combinations of elements from the submodules, so the dimension of the direct sum is the sum of the dimensions of the submodules.
