MHB Direct Sums of Noetherian Modules .... Bland Proposition 4.2.7 .... ....
  • Thread starter Thread starter Math Amateur
    Modules Sums
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am focused on Section 4.2: Noetherian and Artinian Modules and need some help to fully understand the proof of part of Proposition 4.2.7 ... ...
Proposition 4.2.7 reads as follows:https://www.physicsforums.com/attachments/8208In the above proof by Paul Bland we read the following:
" ... ... and since each $$M_i$$ is isomorphic to a submodule of $$\bigoplus_{ i = 1 }^n M_i$$ ... ... "Can someone please explain to me how/why each $$M_i$$ is isomorphic to a submodule of $$\bigoplus_{ i = 1 }^n M_i$$ ... ... ?
Do we know what the submodule is ... ?
Help will be appreciated ...
Peter
Proposition 4.2.7 reads as follows:In the above proof by Paul Bland we read the following:
Peter
What you are asking is the following: If $M$ and $N$ are $R$-modules, then how is $M$ as submodule of $M\oplus N$? Just unravel the definition of $M\oplus N$. $M\oplus N$ as a set is just $M\times N$, where you add and scale coordinate-wise. So a natural embedding of $M$ into $M\oplus N$ is $i:M\to M\oplus N$ given by $i(x)=(x, 0)$. Do you see why $i$ is an injective $R$-module homomorphism?
Thanks for the help, caffeinemachine ... ...
You write:
" ... ... Do you see why $i$ is an injective $R$-module homomorphism? ... ... "
Well ...
$$i( x + y ) = i(x) + i(y)$$ holds because ...
$$i(x+y) = (x+y, 0 ) = (x,0) + (y,0) = i(x) + i(y)$$ ... ...
... and ...
$$i(xa) = i(x) a$$ holds where $$a \in$$ ring $$R$$ holds since ...
$$i(xa) = (xa,0) = (x,0) a = i(x) a$$ ...
So $$i$$ is a homomorphism ...
... and ...
if $$i(x) = i(y)$$ ... then ...
$$(x,0) = (y,0) $$
$$\Longrightarrow x = y$$
... so $$i$$ is injective ...Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
