Direction and magnitude of the average acceleration
In summary, the ball rebounds from a height of 2.5m and has an average acceleration of -828.57m/s due to the floor.
greydog
1. A ball is dropeed from a height of 2.5m and rebounds to a height of 2.1m. If the ball is in contact with the floor for .70ms determine 1: direction and 2: the magnitude of the balls average acceleration due to the floor
I know the equation for average acceleration = change in velocity/ time to make change
I found initial velocity by: v(initial)= sqrt(2*9.8*2.5) = 7m/s
I found final velocity by: v(final)= sqrt(2*9.8*2.1) = 6.42m/s
When i plug those into the avg acceleration equation i have: (6.42m/s - 7 m/s)/.0007s
to get: -828.57m/s So the direction would be down?
Am i doing my math right I am not sure where the negatives go for gravity either. Thanks for your help.
Okay, good start here. But you need to pick a sign convention. Usually we assume that positive is up. See what difference that makes.
do you mean initial velocity should be: v(initial) = sqrt(2*-9.8m/s^2*-2.5m) = 7m/s
and then final velocity would be the same, if so then am i right about the direction being down because the average acceleration is - ? Thanks for helping.
Unfortunately, when you take the square root of a number you get a positive and negative result. This means you have to think about which of the two results applies to your system. Using Ignea_unda's recommendation, what would be the sign of the magnitude of the velocity upon initial contact with the ground?
What would be the sign for the velocity as the ball stops contacting the ground?
Upon initial contact with the ground the sign should be positive, i would think. When the ball hits the ground it is 0. As the ball moves upward, gravity is working on it again, but the ball is moving positively. What am I doing wrong here? It's just not clicking. I hope I'm close though thanks.
The ball is moving downward-- it has downward velocity.
This is true when the ball "bottoms out", somewhere in the .70ms interval.
Yes, it is moving in the positive, up, direction. The velocity is pointing up.
You are close. Just get the signs of the 2 velocities right.
I found this on your forum:
If velocity is (-) (down or to the left) and x (motion) is speeding up, then acceleration will have a (-) sign in front of it.
If velocity is (+) (up or to the right) and x (motion) is slowing down, then acceleration will have a (-) sign in front of it.
So my v(initial) should have negative sign in front and my v(final) should have a positive sign. correct? Then my avg acceleration = 6.42m/s-(-7m/s)/.0007 s giving a positive acceleration therefore a positive direction yes? I hope.
Yep, good work by you!
Yay! Thank you so much for your help! Have a great day!
FAQ: Direction and magnitude of the average acceleration
What is the definition of average acceleration?
Average acceleration is the rate of change of velocity over a given time interval. It is a vector quantity that includes both direction and magnitude.
How is average acceleration calculated?
Average acceleration can be calculated by dividing the change in velocity by the change in time. This can be represented by the equation a = (v2-v1)/t, where v2 is the final velocity, v1 is the initial velocity, and t is the change in time.
What units are used to measure average acceleration?
The SI unit for average acceleration is meters per second squared (m/s^2). However, it can also be measured in other units such as miles per hour squared (mi/h^2) or kilometers per hour squared (km/h^2).
What is the difference between average acceleration and instantaneous acceleration?
Average acceleration is the overall change in velocity over a given time interval, while instantaneous acceleration is the acceleration at a specific moment in time. Instantaneous acceleration is calculated by taking the derivative of the velocity function with respect to time.
How does the direction of average acceleration affect an object's motion?
The direction of average acceleration determines the direction in which an object's velocity is changing. If the average acceleration is in the same direction as the object's velocity, the object will speed up. If the average acceleration is in the opposite direction, the object will slow down. If the average acceleration is at a right angle to the object's velocity, the object will change direction but not speed.
