Direction of frictional force Help
In summary, the direction of the frictional force for each question is as follows: 1) Cannot be determined due to unknown weight and Fnet. 2) Friction upwards to keep block static against weight and F pushing down. 3) Friction to the right opposing motion. 4) Friction to the left, perpendicular to the normal force. 5) Friction upwards to keep block static against weight pushing down. 6) Cannot be determined due to unknown weight and Fnet.
jumptheair
Direction of frictional force! Help!
What is the direction of the frictional force for each question? OR is there not enough info given to answer the question?
1) http://www.learning.physics.dal.ca/library/Graphics/Gtype10/block01-19.gif
2) http://www.learning.physics.dal.ca/library/Graphics/Gtype10/block01-34.gif
3) http://www.learning.physics.dal.ca/library/Graphics/Gtype10/block01-17.gif
4) http://www.learning.physics.dal.ca/library/Graphics/Gtype10/block01-07.gif
5) http://www.learning.physics.dal.ca/library/Graphics/Gtype10/block01-01.gif
6) http://www.learning.physics.dal.ca/library/Graphics/Gtype10/block01-35.gif
frictional force concepts
1) Can't tell, because Fnet is negative but magnitude of weight and F is unknown?
2) Friction up, need it to keep block static against weight and F pushing down.
3) Friction to the right?, because it opposes the direction of motion?
4) Friction to the left, because friction is always perpendicular to the normal force?
5) Friction up, need it to keep block static against weight pushing down.
6) Can't tell, because the magnitude of weight and F is unknown.
I find the direction of frictional force really difficult to grasp.
Feel free to correct me at any point. Thanks
Everything seems good to me except 1 and 4.
For 4 how do you get left?
Just remember : Direction of frictional force on the object is opposite to the direction in which the object is moving or tending to move.
1. Friction down, because it opposes motion? Is this correct? If so, what effect does the decreasing velocity have?
4. Common sense tells me friction would act upwards but my book says the frictional force is ALWAYS perpendicular to the normal force, so I am confused.
yes.
that means that the acceleration is downwards and the net force is downwards.
But the normal force is to the left... so how can the frictional force be to the left?
Oh right! I was thinking that normal force is in opposite direction to gravity, but it's the surface. Thanks!
Related to Direction of frictional force Help
What is the direction of frictional force?
The direction of frictional force is always opposite to the direction of motion or the tendency of motion.
How is the direction of frictional force determined?
The direction of frictional force is determined by the surface on which the object is sliding or rolling. It is always perpendicular to the surface at the point of contact.
Does the direction of frictional force change?
Yes, the direction of frictional force can change depending on the direction of motion or the orientation of the surface. It will always be opposite to the direction of motion or tendency of motion.
What is the difference between static and kinetic frictional force?
Static frictional force acts on objects that are not moving, while kinetic frictional force acts on objects that are in motion. The direction of static frictional force is always opposite to the direction of motion or tendency of motion, while the direction of kinetic frictional force is opposite to the direction of motion.
Can the direction of frictional force be controlled?
The direction of frictional force cannot be controlled directly, but it can be influenced by changing the surface materials or applying external forces on the object.
