Direction of instantaneous axis in rigid body dynamics
In summary, the general motion of a rigid body can be described as a combination of a motion of its center of mass about an axis and its motion about an instantaneous axis passing through the center of mass. This motion is demonstrated through the example of a thin uniform disc welded to a massless stick and rotated on a frictionless plane. The direction of the instantaneous axis can vary depending on the orientation of the disc, as shown in the cases of the disc with its face vertical and horizontal. Further understanding of this concept can be found in a textbook chapter on intermediate mechanics.
arvindsharma
The general motion of a rigid body can be considered to be a combination of (i) a motion of its centre of
mass about an axis, and (ii) its motion about an instantaneous axis passing through the centre of mass.
These axes need not be stationary. Consider, for example, a thin uniform disc welded (rigidly fixed)
horizontally at its rim to a massless stick, as shown in the figure. When the disc-stick system is rotated
about the origin on a horizontal frictionless plane with angular speed w, the motion at any instant can be
taken as a combination of (i) a rotation of the centre of mass of the disc about the z-axis, and (ii) a rotation
of the disc through an instantaneous vertical axis passing through its centre of mass (as is seen from the
changed orientation of points P and Q). Both these motions have the same angular speed w in this case.
Now consider two similar systems as shown in the figure: Case(a) the disc with its face vertical and
parallel to x-z plane; Case (b) the disc with its face making an angle of 45° with x-y plane and its
horizontal diameter parallel to x-axis. In both the cases, the disc is welded at point P, and the systems are
rotated with constant angular speed wabout the z-axis.what is the direction of instantaneous axis (passing through the centre of mass in case (a) and (b).please explain all the concepts in detail.i will be highly thankful.
This would be a topic for a chapter or two in a textbook, not a post on an internet forum. Can you ask a more specific question?
If you really want a textbook chapter, here is one: http://people.rit.edu/vwlsps/IntermediateMechanics2/Ch9v5.pdf
Related to Direction of instantaneous axis in rigid body dynamics
1. What is the direction of instantaneous axis?
The direction of instantaneous axis is the line in which a rigid body is rotating at a specific moment in time. It is also known as the instantaneous rotation axis or the instantaneous center of rotation.
2. How is the direction of instantaneous axis determined?
The direction of instantaneous axis is determined by finding the intersection of the instantaneous velocities of two points on the rigid body. This intersection point represents the instantaneous center of rotation and the direction of the instantaneous axis is perpendicular to the line connecting the two instantaneous velocities.
3. What is the significance of the direction of instantaneous axis in rigid body dynamics?
The direction of instantaneous axis is important in rigid body dynamics as it helps in analyzing the motion of a rigid body at a specific instant. It allows us to understand the direction and magnitude of the rotational motion of a rigid body, which is crucial in many engineering and scientific applications.
4. Can the direction of instantaneous axis change over time?
Yes, the direction of instantaneous axis can change over time as the rigid body rotates. This is because the instantaneous velocities of different points on the rigid body will change as it rotates, leading to a change in the intersection point and the direction of the instantaneous axis.
5. How does the direction of instantaneous axis affect the stability of a rigid body?
The direction of instantaneous axis plays a significant role in determining the stability of a rigid body. If the direction of the instantaneous axis is aligned with the direction of the gravitational force, the rigid body will be in a stable equilibrium. However, if the direction of the instantaneous axis is not aligned with the gravitational force, the rigid body will be in an unstable equilibrium and can topple over.
  • Mechanics
  • Mechanics
