- #36
jbriggs444
- 12,807
- 7,449
I am not suggesting anything at all about the fuel in the tank of the car. I am concentrating on the work done by the surface of its tires on the pavement. In my opinion, if we are discussing kinetic friction then we ought not be discussing fuel, engines or drive trains. We should be discussing kinetic friction. If one insists on phrasing things in terms of energy and if one insists on concentrating only on the energy of the car and ignoring the energy of the pavement then the fact that the resulting statements about energy are not frame invariant is to be expected. Energy is not invariant with respect to choice of inertial reference frame.sophiecentaur said:This is all a bit disingenuous, I think. The source of the Power that we are discussing is the fuel in the tank in the car. You can hardly be suggesting that the fuel in the tank is somehow being 'used' by the Earth, in order to accelerate the car (not an inertial frame, because there is acceleration).
Can you explain your parenthetical about acceleration and inertial frames. Surely the fact that the car has non-zero acceleration (proper or coordinate, take your pick) does not preclude one from using an inertial frame to analyze the situation?
This is not unambiguously true. In the ECI frame, the decrease in the Earth's rotational KE will be roughly equal to the gain in KE of the accelerating car. The discrepancy between the gain and loss will be equal to the total work done in both directions across the pavement/tire interface plus the work done by the engine.There will, of course, be a finite but very small, increase in the KE of the Earth during the interaction.
Edit: Added the clause about the engine above.
If one chooses a more exotic frame from which to analyze the situation, the change in the Earth's KE would become monstrous.
Yes, if one of the surfaces in question is motionless relative to the Earth, we do agree that it simplifies matters to only have to worry about the work being done in one direction. However, not all surfaces subject to kinetic friction are at rest on a [notionally] static earth.We both know that a flat, stationary Earth surface is by far the most sensible frame to be working with.
