Direction of motion if there are two unequal opposite forces
In summary, for a particle at rest on the ground, a force must be applied that produces an acceleration greater than 9.8 m/s^2 in the opposite direction of gravitational acceleration in order for the particle to move upward. Any force less than the force of gravity will not cause the particle to move. Additionally, a net positive force must be applied for the particle to start moving in the desired direction. A force equal to the force of gravity will only keep the particle in place, not cause it to move.
NoahCygnus
96
If a particle is in the state of rest on the ground , and I apply a force such that it produces an acceleration 4.9 ##\frac{m}{s^2}## upward , will it move upward , considering there's gravitational acceleration 9.8 ##\frac{m}{s^2}## in the downward direction, or will it remain at rest?
If the force produces that acceleration, then it must move. But it takes a force of ## (9.8 + 4.9)m ## Newton to do this with a mass ##m##. Any force less than ##mg## and it doesn't move.
So it takes a force which produces an acceleration greater than 9.8 m/s^2 in opposite direction to gravitational acceleration to move the body in upward direction?
The net force on the object must be positive (upward direction) for it to start moving in that direction, if it was initially at rest. If the body were free falling (and thus subject exclusively to gravity), a momentary application of a net positive force will slow it down (reduce its speed) but won't make it instantaneously start going up. This is a common misconception; it is the velocity vector which tells you in which direction the body is moving, not the acceleration.
Likes NoahCygnus
To keep an object in place in a gravitation field it takes a force ##mg## to produce no acceleration whatsoever. It just compensates the gravity force. As Joe says, it's the net force that causes the acceleration.
FAQ: Direction of motion if there are two unequal opposite forces
What happens to an object's direction of motion if there are two unequal opposite forces acting on it?
When there are two unequal opposite forces acting on an object, the object will experience a net force in the direction of the stronger force. This net force will cause the object to accelerate in that direction, changing its direction of motion.
Is there a specific direction that the object will move in?
The direction that the object will move in depends on the relative strengths and directions of the two opposing forces. Whichever force is stronger will determine the direction of the object's motion.
What if the two forces are equal in strength but opposite in direction?
If the two forces are equal in strength but opposite in direction, the object will not experience a net force and will continue to move in the same direction with the same speed. This is known as a state of equilibrium.
Can the direction of motion change multiple times if the two forces keep changing in strength and direction?
Yes, the direction of motion can change multiple times if the two forces keep changing in strength and direction. The object will continue to accelerate in the direction of the net force, which may change as the forces acting on the object change.
How do we calculate the resulting direction of motion when there are two unequal opposite forces?
To calculate the resulting direction of motion, we need to determine the net force acting on the object. This can be done by finding the difference between the two forces and considering their directions. The net force will determine the direction of the object's motion.
