Direction of nonlinear polarization
E_z^2(w)Substituting this into the equation for S_z, we get:S_z = \frac{1}{\epsilon_0 \chi^{(2)}_{zzz}(2w;w,w)}P_z^{(2)}(2w)Since we are only interested in the direction of the nonlinear polarization, we can ignore the numerical value and focus on the direction. So, we can write:P_z^{(2)}(2w) \propto S_zTherefore, the direction of the nonlinear polarization is along the z-axis, as it is proportional to the z-component of the Poynting vector. In summary
snickersnee
34
A linearly-polarized electromagnetic wave with a frequency w and with an
intensity of 1MW/cm2
is propagating in x-direction in a nonlinear crystal with a
refractive index n=1.5. Assume that a second-order nonlinear optical susceptibility tensor
for second-harmonic generation in the nonlinear crystal has only one nonzero component
[itex]\chi^{(2)}_{zzz}(2w,w,w)=10 pm/V (10-11 m/V)[/itex]. The electromagnetic wave is polarized along [itex]\frac{1}{\sqrt{2}}(\hat{y}+\hat{z})[/itex]-direction.
Calculate the amplitude and direction of a nonlinear polarization
oscillating at frequency 2w in the crystal. (Use the expression for the Poynting
vector to deduce the value of E-field in the EM wave and be careful with the
geometry and various factors of 2 when doing calculations.)
Poynting vector: [itex]\vec{S}=<\vec{E} \times \vec{H}>[/itex]
[itex]P_z^{(2)}(2w)=\epsilon_0 \chi^{(2)}_{zzz}(2w;w,w)E_z^2(w)[/itex]
I don't need the amplitude explained, just the direction. (The direction is along z axis, why is that?) The linear polarization is along the same direction as the EM wave. But how do I find the direction for the nonlinear case? I tried crossing [itex]\hat{x}\ with\ \frac{1}{\sqrt{2}}(\hat{y}+\hat{z})[/itex] but that gives [itex]-\frac{1}{\sqrt{2}}(\hat{y}+\hat{z})[/itex] which is wrong.
The direction of the nonlinear polarization can be found by considering the Poynting vector. Since the EM wave is propagating in the x-direction, the Poynting vector will also be in the x-direction, as it is given by the cross product of the electric and magnetic fields.
Using the expression for the Poynting vector, we can write:
\vec{S} = <\vec{E} \times \vec{H}> = <E_xH_z - E_zH_x, E_yH_x - E_xH_y, E_zH_y - E_yH_z>
Since the EM wave is polarized along the \frac{1}{\sqrt{2}}(\hat{y}+\hat{z}) direction, we can write the electric field as:
\vec{E} = <0, E_y, E_z>
Plugging this into the Poynting vector equation, we get:
\vec{S} = <0, E_zH_x - E_xH_y, E_yH_x - E_xH_y>
Since we are only interested in the z-component of the Poynting vector, we can ignore the first two terms. The z-component of the Poynting vector is given by:
S_z = E_yH_x - E_xH_y
To find the direction of the nonlinear polarization, we need to find the direction of the electric field at the frequency 2w. Since the electric field at this frequency is given by:
E_z(2w) = \sqrt{2}E_z(w)
We can write the z-component of the Poynting vector as:
S_z = \sqrt{2}E_z(w)H_x - E_xH_y
Since the electric field and magnetic field at the frequency 2w are perpendicular to each other, we can write:
H_x = \frac{1}{\sqrt{2}}H_z
Plugging this into the equation for S_z, we get:
S_z = \sqrt{2}E_z(w)\frac{1}{\sqrt{2}}H_z - E_xH_y
Simplifying, we get:
S_z = E_z(w)H_z - E_xH_y
Now, using the expression for the nonlinear polarization, we can write:
P_z^{(2)}(2w) = \epsilon_0 \chi^{
Related to Direction of nonlinear polarization
What is the direction of nonlinear polarization?
The direction of nonlinear polarization refers to the orientation of the electric field in a nonlinear material when an external electric field is applied. It is the direction in which the material is polarized, or aligned, due to the applied electric field.
What factors affect the direction of nonlinear polarization?
The direction of nonlinear polarization is affected by several factors, including the strength and direction of the applied electric field, the physical properties of the material, and the symmetry of the crystal structure.
How is the direction of nonlinear polarization measured?
The direction of nonlinear polarization can be measured using techniques such as second-harmonic generation, third-harmonic generation, and sum-frequency generation. These techniques involve measuring changes in the intensity or frequency of light passing through the nonlinear material.
What is the significance of the direction of nonlinear polarization?
The direction of nonlinear polarization is important because it determines the efficiency and direction of nonlinear optical processes, such as frequency conversion and optical switching. It also plays a crucial role in the design and optimization of nonlinear optical devices.
Can the direction of nonlinear polarization be controlled?
Yes, the direction of nonlinear polarization can be controlled by manipulating the physical properties of the material, such as its crystal orientation or temperature. Additionally, the direction can be manipulated by adjusting the parameters of the applied electric field, such as its amplitude and frequency.
