DoobleD
- 259
- 20
When studying Fresnel equations in EM, I very often came across the following type of picture for a s-polarized incident wave on a dielectric interface (http://iqst.ca/quantech/pubs/2013/fresnel-eoe.pdf) :
Many similar diagrams can be found on the internet, for instance http://ecee.colorado.edu/~ecen3400/Chapter%2022%20-%20Reflection%20and%20Refraction%20of%20Plane%20Waves.pdf. My questions is : why is Er pointing in the same direction as Ei does (e.g. towards the positive y) ?
The boundary condition on the E field at the interface is :
Ei + Er = Et
Since Et can't have a higher amplitude than Ei, shouldn't Er points in the opposite direction of Ei (towards negative y) ? And then Hr should of course be reversed as well on the diagram. However the Ei and Er having same direction can be found in the pictures of many different sources, so I suppose it is not a mistake. How can it be ?
Also I know that each E field switch direction as it propagates, but in the above diagram and others similar that I found, Er is drawn at the same z position as Ei and in the same direction, as if both were in phase.
Ei + Er = Et
