Direction of resultant force from a point
In summary, the conversation discusses a problem with Fy, Fx, and FR forces given in pounds and a distance from A given in feet. The solution involves using the arc tangent function to find the angle theta, which is 77.5 degrees. The speaker suggests doing all calculations in pounds and feet to maintain consistency.
goldfish9776
310
I managed to get Fy = 900N , Fx = 200N and FR= 922N , how to get the distance from A is 3.56m ? tetha= arc tan (922/200) = 77.5 degree
The problem is given in units of pounds and feet, so you should do your calculations in the same units.
It is not clear how you arrived at your answers. Please provide your detailed calculations.
BTW, θ = theta, not 'tetha'.
FAQ: Direction of resultant force from a point
What is a resultant force?
A resultant force is the single force that represents the combined effect of multiple forces acting on an object. It is the net force that results from the vector sum of all the individual forces.
How is the direction of a resultant force determined?
The direction of a resultant force is determined by the vector sum of all the individual forces acting on an object. This can be calculated using trigonometry and the principles of vector addition.
Can the direction of a resultant force change?
Yes, the direction of a resultant force can change if the magnitudes and/or directions of the individual forces acting on an object change. The resultant force will always point in the direction of the vector sum of the individual forces.
What happens when the resultant force is zero?
If the resultant force is zero, it means that the vector sum of all the individual forces acting on an object is equal to zero. This can occur when the forces are balanced and cancel each other out, resulting in no overall movement or acceleration of the object.
How is the direction of a resultant force represented?
The direction of a resultant force is typically represented by an arrow pointing in the direction of the force. The length of the arrow can also represent the magnitude of the force, with longer arrows representing larger forces and shorter arrows representing smaller forces.
