Uhh... "anticlockwise" and "counterclockwise" both mean the same thing, you know, "not clockwise".goldfish9776 said:Homework Statement
for the 400cos45 force , i think it should rotate anticlockwise, am i right? but the book gave it is rotated counterclockwise...
Typo, imo it should be in counterclockwise, right? The book gave it in clockwise direction..SteamKing said:Uhh... "anticlockwise" and "counterclockwise" both mean the same thing, you know, "not clockwise".
RIP, Yogi Berra
Nope, guess again.goldfish9776 said:Typo, imo it should be in counterclockwise, right? The book gave it in clockwise direction..
I'm wondering is my direction of 400cos 45 force correct ? Should it point to the left ?SteamKing said:Nope, guess again.
The moment sign convention adopted by the book is a little unconventional. I prefer the right hand rule, which would make CCW moments positive.
The actual convention chosen doesn't matter, as long as you remain consistent throughout your calculations.
Yes, it is correct.goldfish9776 said:I'm wondering is my direction of 400cos 45 force correct ? Should it point to the left ?
then the moment should be anticlockwise , right ? by using right hand rule . I bent my finger from f to F , since it's r cross FSteamKing said:Yes, it is correct.
The moment you showed in Post #6 is indeed CCW.goldfish9776 said:then the moment should be anticlockwise , right ? by using right hand rule . I bent my finger from f to F , since it's r cross F
Ok, then the book is wrong...SteamKing said:The moment you showed in Post #6 is indeed CCW.
No, the moment shown in the book is properly CW.goldfish9776 said:Ok, then the book is wrong...
I m confused now. Then can you show mew the r x f diagram in the book? I have no idea at all.SteamKing said:No, the moment shown in the book is properly CW.
The figure you drew in Post #6 does not match the layout of forces shown in the book, and the direction of that moment is CCW.
You can't change the position of the force relative to the axis of rotation without changing the direction of the moment which is produced.
It's Fig. 3-27(a). Point A is located about half way up the y-axis, while the 400 N force is located about 0.8m from the origin.goldfish9776 said:I m confused now. Then can you show mew the r x f diagram in the book? I have no idea at all.
since the author assume clockwise as positive here , so shouldn't the positive 400cos45 (0.3) rotate anticlockwise? i have drawn a diagram for the moment in the previous post , showing it is rotated in anticlockwise direction... i can't understand why the moment is in clockwise direction for the author...SteamKing said:It's Fig. 3-27(a). Point A is located about half way up the y-axis, while the 400 N force is located about 0.8m from the origin.
You don't need a lot of diagrams and whatnot to figure this out. If point A is the point about which a force causes rotation, you should be able to visualize this from a picture if you can see where the force is applied relative to point A.
The direction of rotation of a moment is the direction in which the force is causing an object to rotate. It is determined by the right-hand rule, where the thumb points towards the direction of the force and the curled fingers indicate the direction of rotation.
The direction of rotation of a moment is directly related to torque. Torque is the product of the force and the distance from the axis of rotation, and its direction is perpendicular to both the force and the distance. Therefore, the direction of the torque will determine the direction of rotation of an object.
Yes, the direction of rotation of a moment can be changed by changing the direction of the applied force or by changing the position of the force relative to the axis of rotation. For example, if the force is applied at a different angle, the resulting moment and direction of rotation will also change.
Understanding the direction of rotation of a moment is crucial in solving problems related to rotational motion and stability. It can also help in predicting the behavior of objects under the influence of external forces and in designing structures or machines that require specific direction of rotation.
The direction of rotation of a moment determines the direction of the angular acceleration of an object. This, in turn, affects the motion of the object, such as its speed, direction of rotation, and stability. The magnitude and direction of the moment also play a role in determining the overall motion of the object.
