Direction of torque vector tilting a spinning top?
In summary, the conversation discusses the use of τ = dL/dt and the reasoning behind the direction of the torque vector in a rotating system. The expert explains that a torque does not rotate, but rather adds a vector to the angular momentum vector. The incorrect reasoning is addressed and the correct understanding of torque and angular momentum is clarified.
Esoremada
52
http://puu.sh/5Qrxt.jpg
τ = dL/dt
I understand the initial and final angular momentum vectors in the diagram, and the answer seems to make sense.
But when I initially solved it my logic was that since the axle itself is rotating clockwise, then the torque vector causing that would point into the page due to the right hand rule - why is this reasoning wrong?
To be honest I've never used τ = dL/dt before, it's on our formula sheet but I don't remember learning it
Hi Esoremada! :smile:
Esoremada said:
… when I initially solved it my logic was that since the axle itself is rotating clockwise, then the torque vector causing that would point into the page due to the right hand rule …
the torque to cause a constant rotation is zero
(same as the force to cause a constant velocity is zero)
in the diagram, the vector L (the angular momentum) for the initial rotation is pointing into the page
the new L is the vector for the new angular momentum
the change in angular momentum, ∆L, is the difference, ie the short vector to the right
all the above is on the RHS of τ = dL/dt
the torque that the question asks for is on the LHS … obviously, it equals lim ∆L/∆t on the RHS :wink:
Likes 1 person
tiny-tim said:
Hi Esoremada! :smile:the torque to cause a constant rotation is zero
Right, I understand that solution, but I don't understand what the problem is with my reasoning that gives the answer into the page:
The entire system has no torque to begin with, just angular momentum
The axle itself is then tilted to the right (from the point of view of the diagram)
This tilt is a clockwise rotation about the centre of mass (again from the point of view of the diagram)
A clockwise rotation requires a clockwise torque, which points IN TO the page
What exactly is wrong with this reasoning?
Let me give another example. Here's a basketball: O
The basketball is in space spinning clockwise if you look down from above (clockwise about the y axis)
So looking straight on from my 'diagram' you see the centre moving to the left.
Now a clockwise torque is applied from this point of view to cause the basketball to accelerate in the clockwise direction (about the x axis). It seems like the increasing rotational speed from this torque would have no connection to the initial rotation about the y axis. Furthermore; applying the solution given to my initial question this basketball after a single full rotation would have had ZERO torque applied since the initial angular momentum vector is pointing straight down again.
… basketball …
that simply isn't the way angular momentum works
if you have a stationary horizontal disc, and you apply a vertical torque to the disc, it makes the disc rotate
but that isn't because it moves the axis (it doesn't), it's because it adds a vertical vector to the original angular momentum vector (which was zero) (and more torque just adds more to the vector, without changing its direction)
a torque does not rotate, it adds
a torque adds a vector to the angular momentum vector​
Likes 1 person
Alright thanks! I've been thinking of torque too much in terms of physical movement rather than the vectors themselves, I think I get it now.
FAQ: Direction of torque vector tilting a spinning top?
What is the direction of the torque vector when a spinning top is tilted?
The direction of the torque vector when a spinning top is tilted is perpendicular to the plane of rotation of the top. This means that if the top is spinning clockwise, the torque vector will point upwards, and if the top is spinning counterclockwise, the torque vector will point downwards.
2. How does the direction of the torque vector affect the movement of a spinning top?
The direction of the torque vector determines the direction in which the spinning top will precess. This means that the top will rotate around a different axis than its spin axis, causing it to move in a circular motion.
3. Can the direction of the torque vector be changed?
Yes, the direction of the torque vector can be changed by tilting the spinning top in a different direction. This will change the direction of the applied force, causing the torque vector to also change direction.
4. How does the direction of the torque vector relate to the angular momentum of a spinning top?
The direction of the torque vector is directly related to the direction of the angular momentum of a spinning top. The torque vector and the angular momentum vector are always perpendicular to each other, and the direction of the torque vector determines the direction in which the angular momentum will change.
5. What is the significance of the direction of the torque vector in understanding the motion of a spinning top?
The direction of the torque vector is crucial in understanding the motion of a spinning top. It dictates the precession of the top and determines how the top will move as it spins. By understanding the direction of the torque vector, we can predict and control the movement of the spinning top.
