Directional and Partial Derivatives .... working from the definitions ....
In summary: Now, since we are interested in the partial derivative \frac{\partial f}{\partial x_j}(x), we set t=0 to get:F'(0) = f'(x + h^{j-1})e^jwhich is equivalent to F'(0) = \frac{\partial f}{\partial x_j}(x).In summary, we can obtain the partial derivative \frac{\partial f}{\partial x_j}(x) by using the chain rule and setting t=0 in equation (2.3) of the proof. I hope this explanation helps you better understand the concepts and equations involved. Keep up
Math Amateur
MHB
3,998
48
I am reading the book "Several Real Variables" by Shmuel Kantorovitz ... ...
I am currently focused on Chapter 2: Derivation ... ...
I need help with an element of the proof of Kantorovitz's Proposition on pages 61-62 ...
Kantorovitz's Proposition on pages 61-62 reads as follows:https://www.physicsforums.com/attachments/7803
I am trying to understand the above proof in terms of the definitions of directional and partial derivatives (in terms of limits) ... but I am having trouble understanding equation (2.3) above ...
I will explain my difficulties in terms of Kantorovitz's definitions as he develops them on page 60 ... as follows:View attachment 7805Now ... I am trying to understand how the definition of partial derivative applies to equation (2.3) in the proof of the proposition ... so for equation (2.1) of the definition we put \(\displaystyle u = e^j\) (because we are dealing with partial derivatives) ... ... and so (2.1) becomes:\(\displaystyle F(t) = f( x + t e^j)\)
so then for \(\displaystyle F_j\) in the proof (see the expression that is above the expression (2.3)) ... we have
\(\displaystyle F_j (t) = f ( x + h^{j-1} + te^j )\) and we appear to be dealing (for some reason?) with \(\displaystyle ( x + h^{j-1} )\) instead of \(\displaystyle x\) ...
... which is OK ... just put \(\displaystyle x = x + h^{j-1}\) ...... BUT ...In Definition 2.1.1 Kantorovitz defines the partial derivative this way:\(\displaystyle \frac { \partial f }{ \partial x_j } := F'(0) = \lim_{ t \rightarrow 0 } \frac{ F(t) - F(0) }{t}\) \(\displaystyle = \lim_{ t \rightarrow 0 } \frac{ f ( x + h^{j-1} + te^j ) - f(x) }{t} \)... ... is the above correct?Now ... my question is as follows: (pertaining largely to equation (2.3) )
What is the definition of \(\displaystyle F_j'(t)\) ... and working strictly and rigorously from the definition how do we obtain
\(\displaystyle F'_j (t) = \frac { \partial f }{ \partial x_j } f ( x + h^{j-1} + te^j )\)
Hope someone can help ...
Peter***NOTE***
I have to say I find it somewhat confusing in trying to work from the definition of partial derivative, that Kantorovitz gives the definition for partial and directional derivative in terms of expressions where \(\displaystyle t\) tends to zero ... and then equation (2.3) above is a partial derivative with \(\displaystyle t\) as a variable ... as in \(\displaystyle F'_J(t)\) ... surely \(\displaystyle t \rightarrow 0\) as per the definition ...
but how does that help us to understand the equation?
Dear Peter,
Thank you for reaching out for assistance with understanding Kantorovitz's Proposition on pages 61-62. I can empathize with your struggles to understand complex mathematical concepts and proofs. I will do my best to explain the concepts and equations in a clear and concise manner.
Firstly, let's review the definitions of directional and partial derivatives as given by Kantorovitz in Chapter 2. For a function f(x), the directional derivative in the direction of a unit vector u is defined as:
f_u'(x) = \lim_{h \rightarrow 0} \frac{f(x + hu) - f(x)}{h}
This definition can be rewritten using the definition of a partial derivative as:
f_u'(x) = \frac{\partial f}{\partial u}(x)
where \frac{\partial f}{\partial u}(x) is the partial derivative of f with respect to u.
Now, in the proof of Kantorovitz's Proposition, we are dealing with the partial derivative \frac{\partial f}{\partial x_j}(x). To better understand this, we can rewrite it using the definition of a partial derivative as:
\frac{\partial f}{\partial x_j}(x) = \lim_{t \rightarrow 0} \frac{f(x + te^j) - f(x)}{t}
Note that e^j is a unit vector in the jth direction. This is why we use it in the definition of the partial derivative.
Now, let's look at equation (2.3) in the proof. This equation is using the chain rule to calculate the partial derivative \frac{\partial f}{\partial x_j}(x). The chain rule states that for a composite function F(t) = f(g(t)), the derivative of F with respect to t is given by:
F'(t) = f'(g(t))g'(t)
In this case, our composite function is F(t) = f(x + h^{j-1} + te^j). The first term, x + h^{j-1}, is a constant with respect to t, so its derivative is 0. The second term, te^j, is a function of t, so its derivative is e^j. Therefore, the derivative of F(t) is given by:
F'(t)
FAQ: Directional and Partial Derivatives .... working from the definitions ....
What is the definition of a directional derivative?
A directional derivative is the rate of change of a function in a specific direction, represented by a vector. It measures the instantaneous rate of change of the function at a given point in the direction of the vector.
How is a directional derivative calculated?
The directional derivative is calculated using the dot product of the gradient of the function and the unit vector in the desired direction. It can also be calculated by taking the partial derivatives of the function with respect to each variable and multiplying them by the components of the direction vector.
What is the difference between a directional derivative and a partial derivative?
A directional derivative measures the rate of change of a function in a specific direction, while a partial derivative measures the rate of change of a function with respect to one variable, holding all other variables constant. In other words, a directional derivative takes into account the slope in all directions, while a partial derivative only considers the slope in one direction.
Can a function have a directional derivative but not a partial derivative?
Yes, a function can have a directional derivative but not a partial derivative. This can occur when the function is not differentiable in one or more directions, but still has a defined rate of change in other directions.
How are directional and partial derivatives used in real-world applications?
Directional and partial derivatives are used in many areas, such as physics, engineering, economics, and computer graphics. They are particularly useful in optimization problems, where the goal is to find the maximum or minimum value of a function. They are also used to analyze the slope and curvature of surfaces, which is important in fields such as computer-aided design and structural engineering.
