I Dirichlet problem boundary conditions
cianfa72
TL;DR Summary
About boundary conditions for Dirichlet problem.
The Dirichlet problem asks for the solution of Poisson or Laplace equation in an open region ##S## of ##\mathbb R^n## with a condition on the boundary ##\partial_S##.
In particular the solution function ##f()## is required to be two-times differentiable in the interior region ##S## and continuous on the boundary ##\partial_S##. The boundary condition specifies its value ##u## at each point on it, hence ##f=u## at the boundary ##\partial_S##.
Now my question is: which is the topology w.r.t one asks the function ##f## to be continuous in the closure ##\bar S## ? I believe it is the subspace topology on ##\bar S## from ##\mathbb R^n## as subset.
Is the above correct? Thanks.
Id say that more than just topology, it's also an issue of Differential Structure, given you want your function to be (twice)differentiable. Given differentiability implies continuity, I suspect Differential Structure would be enough. I suspect you're dealing with the standard topology, but I'm not 100%.
Yes, as far as can I understand, the region where the PDE is solved is an open set ##S## of ##\mathbb R^n## endowed with standard differential structure/topology. Then we have boundary condition on the boundary ##\partial_S##.
The solution ##f## is required to be continuous on the closure ##\bar S##. So the question is: which is the topology on ##\bar S## w.r.t. it is closed anf ##f## is required to be continuous ? My answer: it is the subspace topology from the superset ##\mathbb R^n##.
Unless otherwise stated, when we speak of U \subseteq \mathbb{R}^n we mean the set together with its local affine structure (so that we can calculate derivatives) and the topology induced by the Euclidean inner product. If U \neq \mathbb{R}^n then the restriction to the subspace topology is implied.
The smooth structure is the maximal atlas which contains the charts (V, \mathrm{id}) where V is any open subset of U. (There are always at least two such structures, since (V, <br /> p \ni V \to \mathbb{R}^n : q \mapsto ((q_1 - p_1)^3,q_2 - p_2, \dots, q_n - p_n)) is not smoothly compatible with the identity chart.)
pasmith said:
The smooth structure is the maximal atlas which contains the charts (V, \mathrm{id}) where V is any open subset of U. (There are always at least two such structures, since (V,<br /> p \ni V \to \mathbb{R}^n : q \mapsto ((q_1 - p_1)^3,q_2 - p_2, \dots, q_n - p_n)) is not smoothly compatible with the identity chart.)
You mean fixed a point ##p =(p_1, p_2 \dots p_n) \in V##, your map V \ni q \mapsto ((q_1 - p_1)^3,q_2 - p_2, \dots, q_n - p_n)) is not smoothly compatible with the identity map. However both structures are diffeomorphic (i.e. there exists a diffeomorphism between them).
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
