Dirt, debris, dust, moisture and machines
In summary, the field of engineering or science that studies the issue of enduring dust, debris, dirt, and other contaminants in home equipment and consumer devices is called Tribology. It is also known as "Contamination Control" in the aerospace industry. This topic is often included in product specifications and is handled by mechanical engineers in the design team. Clean rooms are also utilized in manufacturing and assembly processes to maintain a controlled environment.
kenny1999
235
Is our home equipment and many other consumer's device usually designed to endure dust, debris, dirt or anything (even virus or bacteria) from the environment which is hard to avoid? What is the field of engineering or science
that studies such issue?
https://www.enclosurecompany.com/ip-ratings-explained.php
Likes Lnewqban
It would start as part of the product specification. Product specifications are written by top management with input from marketing. This part of the product specification would be given to a mechanical engineer on the design team.
"Clean rooms" is a topic that may relate to your questions. There are many circumstances where manufacture and assembly are done in a clean room environment.
Likes Lnewqban
Delayed response, but the field of engineering is called "Contamination Control", at least when dealing with the aerospace industry.
Likes Tom.G and russ_watters
Related to Dirt, debris, dust, moisture and machines
What is dirt?
Dirt is a substance made up of small particles of soil, sand, and other organic matter. It can be found on the ground, on surfaces, and in the air.
What is debris?
Debris refers to any type of scattered or broken pieces of material. It can include things like rocks, branches, and trash.
What is dust?
Dust is a fine, dry powder made up of small particles of dirt, debris, and other substances. It can be found in the air and can cause respiratory problems if inhaled.
What is moisture?
Moisture is a term used to describe the presence of water or other liquid in a substance or environment. It is essential for the growth of plants and can also be damaging to machines if it causes rust or corrosion.
What role do machines play in the presence of dirt, debris, dust, and moisture?
Machines can contribute to the presence of dirt, debris, dust, and moisture in a few different ways. They can generate dust and debris through their operations, and they can also become clogged with dirt and debris if not properly maintained. Additionally, machines can be affected by moisture, leading to rust and other damage if not properly protected.
