Discharge of capacitor question
In summary, the electric field created by the changing magnetic field does not contribute to the momentum of the charges on the wire.
CAF123
88
A charged parallel plate capacitor with plates in the x-y plane and uniform electric field ##\mathbf E = E\hat z## is placed in a uniform magnetic field ##\mathbf B = B \hat x##
i) A resistive wire is connected between the plates in the ##\hat z## direction, so that the capacitor slowly discharges. Show that the total impulse on the wire during the discharge is equal to the momentum orginally stored in the fields.
ii) Instead of discharging the capacitor, slowly reduce the magnetic field to zero. Show again that the resulting total impulse on the plates is equal to the momentum stored in the fields.
[/B]
momentum stored in the fields ##\mathbf P = \frac{1}{c^2} \int_V d^3 r \mathbf S##
lorentz force.
(Working in lorentz heaviside units)[/B]
i) is fine. The momentum stored in the fields is given by above equation, and before the discharge E and B are constant so the momentum is ##(EBAd/c) \hat y## where A is the area of the plates and d is the distance between them.
Then (magnetic) force on wire is $$\mathbf F = \frac{1}{c} \mathbf I \times \mathbf B = \frac{1}{c}Id \hat z \times B \hat z = (dIB/c) \hat y \Rightarrow P_{impulse} = \int F dt = dB/c \int_o^T - \frac{dq}{dt} dt = \dots = \text{result},$$ where t=T is the time when there is zero charge left on the plates.
This gives the correct result but why did the electric field not come into play when it accelerates the charges along the wire?
ii) I am not quite sure how to begin. The changing magnetic field will induce a circular electric field.
Thanks!
Hi. For (i) i think since the charges are accelerated (by the E-field) along the z-direction that doesn't contribute to the wire's momentum (there are forces on the plates but they cancel if the plates are fixed).
For (ii), it seems that by symmetry the E-field created by the changing B-field should only have components along the y-axis (think about what B-field two parallel current sheets would create if currents in the sheets ran in the y and –y direction); but in any case we still have to assume the plates are fixed in the z-direction since otherwise the constant E-field would bring them together and the problem would get more complicated...
So the changing B-field would produce: E (z) = (z/c)j ∫dt B(t) , and the total impulse would be: ΔP = qΔE = qB(0)d/c = EBAd/c as advertised
Sorry i just realized i shouldn't have spelt out the whole answer, i apologize.. but then i might be wrong! :)
Related to Discharge of capacitor question
What is the discharge of a capacitor?
The discharge of a capacitor refers to the process of releasing stored electrical energy from the capacitor. This happens when the capacitor is connected to a circuit or when its terminals are short-circuited.
How does the discharge of a capacitor occur?
The discharge of a capacitor occurs due to the flow of electrons from one plate of the capacitor to the other, creating a current. This process continues until the capacitor is fully discharged and the voltage across its terminals reaches 0.
What factors affect the discharge of a capacitor?
The discharge of a capacitor is affected by its capacitance, voltage, and resistance in the circuit. A higher capacitance and voltage will result in a longer discharge time, while a higher resistance will cause the discharge to happen more slowly.
What is the equation for calculating the discharge time of a capacitor?
The equation for calculating the discharge time of a capacitor is t = RC, where t is the time in seconds, R is the resistance in ohms, and C is the capacitance in farads.
What is the difference between a complete and partial discharge of a capacitor?
A complete discharge of a capacitor occurs when all of its stored energy is released, resulting in a voltage of 0. A partial discharge, on the other hand, occurs when only a portion of the stored energy is released, resulting in a voltage that is not 0.
