Discharging a capacitor - how long does it take
  • Thread starter jsmith613
  • Tags
    Capacitor
In summary: You can use any set of Q,I, and V which hold at a given instant; It just so happens that you know those particular values. And the R=V/I is constant... that's the leakage resistance you worked out...
jsmith613
614
A capacitor stores 1.09 C of charge.
The capacitor has a p.d of 16V and a capacitance of 68 000 µF.
The maximum leakage current is 0.003 µA per µF per V therefore for this capacitor the maximum leakage current = 3260 µA.
How long does it take for the capacitor to discharge by leaking?
So Q=It
therefore t = Q/I = 334 seconds
BUT apparently this is the time constant, why?
(now I realize my method is wrong because discharging current will change but I have no idea how to do this Q so just thought I would use Q=It)
At any time t, the current flowing from the capacitor is given by the differential equation:
1/C * dVc(t)/dt = ...
how does this help me fidn the time constant and then (5RC) time to discharge?
The dots ... indicate where you fill in using the data you are given.
but I don't have dVc(t)/dt
Expressing it in symbols rather than words:
Ic(t) = 1/C * dVc(t)/dt = ...
sorry...I am very much confused...
What i still don't see is why the t I found using Q/I was time constant...I realize it is not discharge time but cannot see why it is time constant...
You are told what the capacitor's leakage current is, here:
the leakage current is 0.003 µA per µF per V
yes so leakage current changes BECAUSE p.d will change...but this also means dV/dt changes...
It means V changes. So you express leakage current in terms of V, and this leads to a differential equation to solve.
You may gather some insight though unit analysis. Take a look at the units of the leakage specification. If capacitance remains constant, how does the leakage current vary with the capacitor voltage? What do the units remind you of?
this is A2 physics...we don't need to solve differential equations...note the question was only worth 2 marks so clearly this cannot be the solution
This is what the MS wrote:
Estimate of time for capacitor to discharge with reasoning:
Q/I0 = 334 s [This is time constant] (1) - why??
Q=1.09
Numerical example such as: for less than 0.7% remaining t = 5τ =
1670 s OR well-reasoned estimate showing t >> 300 s (1)
(I know this bit BUT NOT the first bit??)
Leakge: uA/uF/V
If capacitance is constant then we get uA/V
this = 1/R
Avoiding the D.E. makes it too easy! :-p
yes but that's all I need (no D.E but working as per mark scheme)...I am still struggling to get why the mark scheme is correct
Given the voltage V on capacitor C, what's the value of the charge Q on the capacitor?
gneill said:
given the voltage v on capacitor c, what's the value of the charge q on the capacitor?
q=cv
=v*680000*10-6
jsmith613 said:
q=cv
=v*680000*10-6
Yes, but the numerical value is not important for the moment. If you divide both sides by I what do you get?
Q/I = RC...
ok...so the next question is why must I use the initial current...I presume this is because I am also using the initial charge, right?
jsmith613 said:
Q/I = RC...
You can use any set of Q,I, and V which hold at a given instant; It just so happens that you know those particular values. And the R=V/I is constant... that's the leakage resistance you worked out earlier.
you are amazing...thanks so much for explaining this to me so well (and walking me through rather than telling me straight out...it means I won't make the same mistake in the exam) :)
Glad to help. Good luck in your exams :smile:
sorry for brining this up again...but I was looking at the charge/discharge curve and realized something...I just wanted to check:
would I be correct in thinking that this method would only hold true for a DISCHARGING capacitor...for a charging capacitor charge increases and current decreases...thus initial Q/I = small and final Q/I = large
silly me
I should be looking at the Q and V curve
both either increase or decrease at the same rate...therefore it should work for bothh...i think...really not sure though
jsmith613 said:
silly me
Yup, should work for both. The initial slopes of the Q vs t or V vs t curves are finite so long as the resistance in the discharge path is nonzero and finite.
actually this could ONLY work for discharging as they are talking about leakge current...how can a charging capacitor leak charge...
but...actually I cannot think of an example...I was trying to make an example to prove the situation for charging and discharging...maybe you can?
if not I will just take your word for it and hope nothing too hard comes up :)
also is not R the resistance of the resistor...its V is NOT the same as the V of the capacitor...how then does this work for a charging circuit?
I realize the comment was foollish...it is discharging to the surroundingg...the resistance to disharging is R=V/I...silly me
just to check though, for a discharging capacitor, is the voltage across the resistor the same as that cross the capacitor BUT the for a charging capacitor the sum of the p.d's across the capacitor and resistor = source (i.e: they are not the same at all points)??
For this problem the circuit resistance happens to be provided by a leakage resistance of the capacitor, but it's not a requirement; The resistance could be given as an external component (or even an external resistance in parallel with a leakage resistance).
The point to take from this problem is that the initial slope of the Q vs t, V vs t, or I vs t curves for charging or discharging is determined by the time constant of the circuit.
If this problem had been about a charging capacitor rather than a discharging one they couldn't have given you the initial charge on the capacitor; They would have had to provide some other set of parameters that would allow you to determine the time constant.
this is something new I learned from this...I always assumed resistance cam from an extneral source...but it can come from anywhere...this is definitely a great insight into the physics of capacitors :)
  • #31
For the typical charging capacitor circuit, the sum of the resistor and capacitor p.d.'s is constant (equal to the voltage source).
Of course, for any complete "tour" around a given circuit the sum of all potential changes must be zero according to Kirchhoff.
  • #32
yes...thanks :)
for this I just learn sum of p.d across componenets = emf of source (assuming wire have no resistance / no internal resistance)
Related to Discharging a capacitor - how long does it take
What is a capacitor and how does it work?
A capacitor is an electronic component that stores electrical charge. It consists of two conductive plates separated by an insulating material, known as a dielectric. When a voltage is applied to the capacitor, one plate becomes positively charged and the other becomes negatively charged, creating an electric field between them. This electric field stores energy in the form of electrical charge.
What is discharging a capacitor?
Discharging a capacitor refers to the process of releasing the stored electrical charge from a capacitor. This can be done by connecting the two plates of the capacitor together, allowing the charge to flow from one plate to the other until the capacitor is fully discharged.
How long does it take for a capacitor to discharge?
The time it takes for a capacitor to discharge depends on several factors, including the capacitance of the capacitor, the voltage across the capacitor, and the resistance of the circuit. Generally, the larger the capacitance and voltage, and the lower the resistance, the longer it will take for the capacitor to discharge.
What is the formula for calculating the time it takes for a capacitor to discharge?
The time it takes for a capacitor to discharge can be calculated using the formula t = RC, where t is the time in seconds, R is the resistance in ohms, and C is the capacitance in farads. This formula assumes that the capacitor is discharging through a resistor in a simple RC circuit.
How can the time it takes for a capacitor to discharge be affected by external factors?
The time it takes for a capacitor to discharge can be affected by external factors such as temperature, humidity, and the type of dielectric material used in the capacitor. These factors can alter the capacitance and resistance of the circuit, thus affecting the discharge time. Additionally, the presence of other components in the circuit can also impact the discharge time.
  • Electrical Engineering
  • Electromagnetism
