Discharging a capacitor, how variables change over time
In summary, the conversation discusses a parallel plate capacitor with a wire of resistance R placed between the plates, and how the voltage, current, and stored energy change over time. The equations I = (V/R) exp (-t/RC) and V=Q/C are used to determine the decline of current and potential difference, with the conclusion that both are exponentially declining with time. The potential difference can also be written as V(t) = V exp (-t/RC), where V is the total charge at t=0.
tomwilliam2
117
I have a parallel plate capacitor of area A, width d, potential difference V between the plates, and it is disconnected from the source of emf. A wire of resistance R is placed between the plates to allow a current to flow. Draw a sketch to show how the voltage, current and stored energy change over time.
The capacitance and resistance are constants I think, as they depend only on the physical characteristics of the setup. So I know that I/V will see an exponential decline over time, tending to zero as t tends to infinity. What I don't know, is how each of them varies individually. I presume the potential difference between the plates will tend to zero, so V will decrease over time (exponentially as well?) and that the current can only flow with a voltage difference. I suspect that they both decline exponentially but can't work out how to demonstrate this.
It might involve I = dQ/dt and V= Ed, but I can't get any further than that.
I guess the energy must decline faster though, as U = 0.5CV^2 and V is declining exponentially.
Any help greatly appreciatec
You have correctly found the current I(t).
Since there is just the resistor and capacitor in the circuit, and nothing else, they both have the same current and potential difference. Since you have I, try to think if either the resistor or the capacitor can be used somehow to determine V(t), given the I(t) you have.
(Too bad they chose to call the initial potential difference V, since that is often used for a varying potential difference. So my "V(t)" means the one varying over time, not the initial "V".)
Thanks very much.
So I know that for the current across the capacitor:
I(t) = dQ/dt
And that this is also the current across the resistor.
The potential difference across the capacitor is (rearranging the equation given):
V_c(t) = IR exp (t/RC)
V_c(t) = (dQ/dt)R exp (t/RC)
Which is also the potential difference across the resistor. I can use V=Q/C to get
Q/C = (dQ/dt)R exp (t/RC)
Or maybe
I = (Q/CR) exp (-t/RC)
But isn't Q here actually Q(t) as the charge on the plates is a function of time?
This would give me
V = (Q/C) exp (-t/RC)
Meaning that both the current and the potential difference were exponentially declining with time. Is that correct?
tomwilliam2 said:
Thanks very much.
I(t) = dQ/dt
That's fine, but I'll just say it would have gone much easier if you had thought about the resistor instead of the capacitor. How are p.d. and current related to each other for a resistor?
This would give me
It is correct, however Q and C are not "givens" in the problem statement. Can you write it in terms of the given parameters?
Ah, I think I've got it. It comes out as
Where V is the total charge at t=0. I see what you mean, it's confusing that V is the starting PD and the variable which changes with time...
Thanks very much for your help
You're welcome, glad it worked out.
FAQ: Discharging a capacitor, how variables change over time
How does the capacitance affect the discharge time of a capacitor?
The capacitance of a capacitor directly affects its discharge time. A higher capacitance means that the capacitor can store more charge, which results in a longer discharge time. Conversely, a lower capacitance will result in a shorter discharge time.
How does the voltage affect the discharge time of a capacitor?
The voltage across a capacitor also has an impact on its discharge time. A higher voltage means that the capacitor can store more charge, resulting in a longer discharge time. Similarly, a lower voltage will result in a shorter discharge time.
How does the resistance in the circuit affect the discharge time of a capacitor?
The resistance in the circuit also plays a role in the discharge time of a capacitor. A higher resistance will result in a slower discharge time, as the flow of current is restricted. Lower resistance will result in a faster discharge time.
How does the type of capacitor affect its discharge time?
The type of capacitor used can have an impact on its discharge time. Different types of capacitors have different capacitance values and can handle different voltages, which can affect the discharge time. Additionally, factors such as the dielectric material used can also impact the discharge time.
How does the temperature affect the discharge time of a capacitor?
The temperature can also have an effect on the discharge time of a capacitor. In general, higher temperatures can result in a faster discharge time, as the molecules in the capacitor can move more freely, allowing for a faster flow of current. However, excessive heat can also damage the capacitor and affect its overall performance.
