Discharging capasitors and it's general electrical propertie
In summary, when two different capacitors are in series with a resistor, the current and voltage will both drop exponentially. The capacitance of the capacitors will remain the same over time, but the charge on them may not be the same due to the current decreasing. However, charge is a conserved quantity, so the total charge in the circuit will remain constant.
1832vin
58
It's just that I've never properly sorted this confusion of mind, so i would like to sort it out
so it 2 different capacitors are in series with a resistor: (let's say 0.15F, 0.45F, 150M ohm)
1. both current and voltage drops exponentially
2. capacitance on capacitors remain same over time?
2. the charge on capacitors is same over time?
because Current decreases, and Time increases, does that mean Charge (Q=I*T) is unchanged
3. at t=0 charge on cap 1 = charge on cap 2?
Since they're in series, current should be same, therefore charge is same? But Q=CV, and capacitance is differentthankyou.
You mean the two capacitors and the resistor are all in series?
If all three components are in series then the two capacitors are equivalent to a single capacitor. You are needlessly complicating the situation by having two capacitors instead of one. Let's take a 1 F capacitor in series with a 1 ohm resistor.
Yes.
Yes. The capacitance of an ideal capacitor is a constant.
3. the charge on capacitors is same over time?
More basic than that. If you have a pool of charge and drain some charge, the pool shrinks. Charge is a conserved quantity.
If we have the two terminals of a 1F capacitor connected to the two terminals of a 1 ohm resistor then current decays by a factor of 1/e every second. If it starts charged at 1 Volt then the capacitor also starts with 1 Coulomb of charge.
After one second, there is only about 0.37 Volts and 0.37 Coulombs. 0.63 Coulombs having drained through the resistor at an average of 0.63 amps during that first second.
After two seconds there is only about 0.14 Volts and 0.14 Coulombs remaining. 0.23 Coulombs having drained through the resistor at an average of 0.23 amps during that second second.
After three seconds there is only about 0.05 Volts and 0.05 Coulombs remaining. 0.09 Coulombs having drained through the resistor at an average of 0.09 amps during that third second.
In the general case of two charged capacitors discharging in series with a resistor, the result can be that the two Cs can end up with (opposite) charges on them when the current has stopped flowing. It all depends on the values and the initial charges.
Related to Discharging capasitors and it's general electrical propertie
1. How do capacitors store and release electrical energy?
Capacitors store electrical energy by storing opposite charges on two conductive plates separated by an insulating material, known as a dielectric. When a voltage is applied, the charges are stored on the plates and create an electric field. To release the energy, the capacitor discharges the stored charges, creating an electric current.
2. How does discharging a capacitor affect its electrical properties?
Discharging a capacitor reduces the amount of electrical energy it can store. The voltage across the capacitor decreases as the stored charges are released. The capacitance, or ability to store charge, remains the same. The time it takes for a capacitor to discharge is determined by its capacitance and the resistance of the circuit it is connected to.
3. Can a capacitor be discharged without a resistor?
Yes, a capacitor can be discharged without a resistor, but it is not recommended. Without a resistor, the capacitor will discharge quickly, potentially causing a surge of current that could damage the capacitor or other components in the circuit. It is best to use a resistor in series with the capacitor to control the discharge rate and prevent damage.
4. How does the type of dielectric affect the electrical properties of a capacitor?
The type of dielectric used in a capacitor can affect its capacitance, maximum voltage rating, and other properties. Some commonly used dielectrics include air, paper, ceramic, and various types of plastic. Each type has different properties that make it suitable for different applications. For example, ceramic capacitors have a high capacitance but a lower maximum voltage rating compared to plastic film capacitors.
5. Can a capacitor hold a charge indefinitely?
No, a capacitor cannot hold a charge indefinitely. Over time, the charges stored on the plates will slowly leak away, and the capacitor will discharge. This process is known as self-discharge and is influenced by factors such as the type of dielectric and the temperature. However, some capacitors, such as supercapacitors, have a higher capacitance and can hold a charge for longer periods than traditional capacitors.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
