Disconnector Operating Mechanism
  • Thread starter muet
  • Tags
    Mechanism
In summary, a disconnector that is motor operated can only be operated from a control panel or switch yard.
muet
Information : CS11G Manual operation or CJ6B motor operated , for GW4F-145 type dis-connectors,
Hi Friends,
i am very confused, about dis connectors , if these are Off Line operated then what is the use of Motor operated ?
2nd , if motor operated mechanism is installed then controls of that are in control room in control panel or in switch yard, ?
thanks
A disconnect is just a switch that should open/close only when the current is zero. Contrast that with a circuit breaker type of switch which can open when current is flowing.
Both types of switch can be locally operated or remotely operated using a motor actuator.
Does that answer your question?
what you mean by remotely operated, i mean the control panel is situated in the control room right ?, 2nd what about the ON-Load operation of dis connector what is the difference between ON Load or NO Load ?
If there is a remote operator, it could be anywhere, yard or control room.
A disconnect switch is meant to be operated only
  1. If the switch is closed, and if there zero load current, then it can open.
  2. If the switch is open, and if no load is attached, then it can close.
The video below shows the bad things that can happen if you open a disconnect while load current is flowing.
If you know Chinese you may read this:
http://www.chintelectric.com/Upload/File/20140826142449.pdf
However, as anorlunda already said, it is an usual disconnector of 145 kV 2000 A rated.
You have at first to open the circuit breaker and after then to close or open it. It will support 145 kV between contacts if it is open. contacts if it is open. You have to lock the disconnector if the circuit breaker is close and unlock if it is open.
In the position of open breaker you may close or open the disconnector by means of a motor if you have a voltage source, but you can act it manually-if the electric source is missing.
FAQ: Disconnector Operating Mechanism
What is a disconnector operating mechanism?
A disconnector operating mechanism is a device used to open and close disconnector switches in electrical systems. These switches are used to isolate different sections of a power grid or electrical equipment for maintenance or repairs.
Why is a disconnector operating mechanism important?
A disconnector operating mechanism is important because it allows for the safe and efficient operation of disconnector switches. These switches are crucial for the maintenance and protection of electrical systems, and the mechanism ensures that they are activated properly.
How does a disconnector operating mechanism work?
A disconnector operating mechanism typically consists of a motor or manual crank that rotates a shaft connected to the disconnector switch. This rotation causes the switch to open or close, depending on the desired function. Some mechanisms also include safety features, such as position indicators, to ensure proper operation.
What are the different types of disconnector operating mechanisms?
There are several types of disconnector operating mechanisms, including motor-operated, manual crank, and hydraulic mechanisms. Motor-operated mechanisms are commonly used for larger switches, while manual crank mechanisms are often used for smaller switches. Hydraulic mechanisms are typically used for high voltage switches or in harsh environments.
How do you maintain a disconnector operating mechanism?
To maintain a disconnector operating mechanism, regular inspection and lubrication are necessary. The mechanism should also be tested periodically to ensure proper operation. Any worn or damaged parts should be replaced promptly to prevent potential malfunctions. It is also important to follow the manufacturer's maintenance guidelines for the specific type of mechanism being used.
