MHB Discontinuity: Asymptotic discontinuity
  • Thread starter Thread starter samir
    Discontinuity
Asymptotic discontinuity refers to points where a function is discontinuous due to limits being infinite, leading to vertical and horizontal asymptotes. The function f(x) = 1/x exemplifies this, as the limit approaches infinity when x nears zero, indicating a vertical asymptote. It is clarified that while infinity is not a number, the limit notation is well-defined in mathematical contexts. The discussion also explores whether functions can have vertical asymptotes without horizontal ones, and vice versa, confirming that such scenarios are possible. Overall, asymptotic discontinuity plays a crucial role in understanding the behavior of functions near points of discontinuity.
samir
Hi again!
I thought I would finish off my previous posts on discontinuity by discussing asymptotic discontinuity. So let's focus on these alone in this thread.
I'm not familiar with the origin of the term "asymptote", but from what I can tell, it has asymptotic discontinuity to thank for for its existence. That is to say asymptotic discontinuity is the reason we have these vertical and horizontal lines that we call asymptotes.
So what is asymptotic discontinuity? The simplest explanation I can think of is that it's the point at which a function is discontinuous because the limit at the given point is unreachable, because it's infinite!
Assume we have the following function.
$$f(x)=\frac{1}{x}$$
How do we show that this function has vertical and horizontal asymptotes? My current understanding is that we have to show that the limit is infinite. But how do we do that?
For the vertical asymptote, I believe that we can write something like this:
$$\lim_{{x}\to{0^{\pm}}}f(x) \rightarrow \frac{1}{x}= \infty$$
Letting x approach 0 implies that the quotient approaches infinity.
But I don't think we can write this:
$$\lim_{{x}\to{0^{\pm}}}f(x)= \infty$$
Because x is not allowed to be equal to zero. The function is undefined at x=0.
$$\lim_{{x}\to{0^{\pm}}}f(x)= \text{undefined}$$
Or am I looking at this the wrong way? Is the limit in fact equal to infinity? Surely nothing can really be equal to infinity as infinity is not even a number?
What about the horizontal asymptote? How do we show that this function has a vertical asymptote? Do we have to solve for the dependent variable and kind of do the same thing in reverse?
Now, is it only rational functions that have asymptotes? I have mostly seen this type of function having an asymptote. I know tangent function also has asymptotes. But that has to do with the definition of what a tangent function is. We can't divide by zero.
Can a function have a vertical asymptote but no horizontal asymptote? I would say yes.
Can a function have a vertical asymptote and a horizontal asymptote? I would say yes to that too.
But can a function have a horizontal asymptote alone, and no vertical asymptote? I'm not so sure of that.
Mathematics news on Phys.org
That's true for vertical asymptotes and they occur as the function approaches some constant value. For horizontal asymptotes the limit is some constant, for example
$$\lim_{x\to\infty}\tan^{-1}(x)=\dfrac{\pi}{2}$$
Yes. $\tan(x)$ is an example.
That's correct.
Yes, it can. $\tan^{-1}(x)$ is such a function.
$\lim_{x\to0^\pm}\dfrac1x=\pm\infty$ and it's purely a notational convention. As you say, infinity is not a number and can't be treated as such in the sense of real numbers. There are systems, such as the extended reals, where infinities are treated somewhat differently.
A bit of humor:
"Infinity isn't a number, it's a place."
-"What place is that?"
"Not anywhere near here."
The notion $\lim\limits_{x \to 0^+} \dfrac{1}{x} = \infty$ is actually well-defined, and can be stated without mentioning infinity:
"For any positive (real) number $M$ there exists a positive real number $\delta$ such that if $0 < x < \delta$, then $\dfrac{1}{x} > M$".
Informally, "$\dfrac{1}{x}$ grows without bound as $x$ nears 0 from the right."
I especially like the sentence:
With these definitions $$\overline{\mathbb{R}}$$ is not a field, nor a ring, and not even a group or semigroup. However, it still has several convenient properties.
In other words, it violates all known algebraic structures, but it's still useful. (Wink)
One can also form the *hyperreals*, which not only contain "infinities", but also *still* remain a field.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
