I Discontinuous systems? And why do we need uniqueness anyway?
  • I
  • Thread starter Thread starter askmathquestions
    Systems Uniqueness
askmathquestions
Much of the theory of ordinary differential equations is based around continuous derivatives. A lot of nice theories came together with semi-group theory of linear systems and the Banach contraction theorem, but these are limited to continuous functions. Then you get into partial differential equations and uniqueness is generally applied to PDE with analytic coefficients.
Can we introduce functions with a finite number of step discontinuities and still achieve uniqueness? Such functions are Riemann-integrable correct? So, does uniqueness hold for some classes of ##L^1## functions?
If not, can we identify the points where the trajectories are not unique, and decide "which" trajectory is chosen with some book-keeping of the inertia or "direction" of a trajectory?
If you think about this physically, a car or bike on a 2D surface might go in a loop-de-loop, it's trajectory will overlap with itself at multiple points. You'll notice this doesn't magically stop the car from attaining a smooth, continuous trajectory, even though mathematically, multiple trajectories may intersect with themselves or each other and and are therefore not unique.
Analogously, I don't believe uniqueness should truly be a problem for non-unique solutions to differential equations, so long as we can keep track of the "direction" or "inertia". But, how do we do that? What constraint or assumptions do we introduce to differential equations to attain continuous and practical trajectories that may model physical phenomena where trajectories are not necessarily unique?
What have you learned about this in your studies so far?
Are you asking "if we have a problem which has multiple solutions, can we introduce additional information that makes the solution unique"? What do you think the answer is?
Yes, so ## \dfrac {dy}{dx} = f(x, y) ## is not a good model for a car's motion. Can you think of a better one?
Given your answers to my questions above, do you think there is a unique way of determining these additional constraints?
Its trajectory in ordinary space, but ordinary space is not the correct space to be looking at if you want uniqueness. For a deterministic system, the trajectory in phase space is what must be unique (no overlapping with itself--although it is possible for an idealized system to have a phase space trajectory that is a closed curve).
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
