YLW
- 8
Hi,
I'm new so I hope I post at the right place ( I think I posted wrongly once already).
(http://discovermagazine.com/2010/apr/01-back-from-the-future/article_view?b_start:int=1&-C=)
I was just reading about this article on Discover Magazine which suggests that experiments show that events in the future may affect results in the past.
Has anybody read it – does it suggest retrocausality?
Some excerpts are here.
Just last year, physicist John Howell and his team from the University of Rochester reported success. In the Rochester setup, laser light was measured and then shunted through a beam splitter. Part of the beam passed right through the mechanism, and part bounced off a mirror that moved ever so slightly, due to a motor to which it was attached. The team used weak measurements to detect the deflection of the reflected laser light and thus to determine how much the motorized mirror had moved.
That is the straightforward part. Searching for backward causality required looking at the impact of the final measurement and adding the time twist. In the Rochester experiment, after the laser beams left the mirrors, they passed through one of two gates, where they could be measured again—or not. If the experimenters chose not to carry out that final measurement, then the deflected angles measured in the intermediate phase were boringly tiny. But if they performed the final, postselection step, the results were dramatically different. When the physicists chose to record the laser light emerging from one of the gates, then the light traversing that route, alone, ended up with deflection angles amplified by a factor of more than 100 in the intermediate measurement step. Somehow the later decision appeared to affect the outcome of the weak, intermediate measurements, even though they were made at an earlier time.
