Discovering Cancellations: $(1+x)^2/(1-x^2)$
  • MHB
  • Thread starter soroban
In summary: Your Name]In summary, we discussed several examples of cancellations in fractions and fractional exponents, known as "hidden fractions." These cancellations occur when the numerator and denominator share a common factor that can be reduced, resulting in simplified fractions. These cancellations are based on fundamental principles of algebra and are commonly used in higher level mathematics.
soroban
194
You have probably seen these cancellations.
$\displaystyle\quad \frac{16}{64} \;=\;\frac{1\rlap{/}6}{\rlap{/}64} \;=\;\frac{1}{4}$
$\displaystyle\quad \frac{26}{65} \;=\;\frac{2\rlap{/}6}{\rlap{/}65} \;=\;\frac{2}{5}$
$\displaystyle\quad \frac{19}{95} \;=\;\frac{1\rlap{/}9}{\rlap{/}95} \;=\;\frac{1}{5}$But have you seen this one?
$\displaystyle \quad \frac{(1+x)^2}{1-x^2} \;=\;\frac{(1+x)^{\rlap{/}2}}{1-x^{\rlap{/}2}} \;=\;\frac{1+x}{1-x}$
Dear forum members,
Thank you for bringing these cancellations to my attention. I am always fascinated by patterns and relationships in mathematical equations. These cancellations are a great example of how seemingly complex expressions can be simplified and reduced to more manageable forms.
The first three cancellations you shared are known as "hidden fractions" or "hidden cancellations." They occur when the numerator and denominator of a fraction share a common factor that can be reduced. In the first example, both the numerator and denominator can be divided by 16, resulting in a simplified fraction of 1/4.
Similarly, in the second and third examples, the numerators and denominators can be divided by 13 and 19, respectively, resulting in simplified fractions of 2/5 and 1/5.
However, the last cancellation you shared is a bit different. It involves the use of fractional exponents, which can also lead to cancellations. In this case, both the numerator and denominator can be rewritten as fractional exponents with the same base, allowing for the cancellation to occur.
These types of cancellations may seem surprising, but they are actually based on fundamental principles of algebra and can be proven mathematically. They are also commonly used in simplifying and solving equations in higher level mathematics.
Thank you again for bringing these cancellations to my attention. I hope this explanation has helped shed some light on the topic and sparked your interest in exploring more mathematical patterns and relationships.
FAQ: Discovering Cancellations: $(1+x)^2/(1-x^2)$
What is the formula for $(1+x)^2/(1-x^2)$?
The formula for $(1+x)^2/(1-x^2)$ is a mathematical expression that involves squaring the sum of 1 and x, and then dividing it by the difference of 1 and the square of x.
How do you discover the cancellations in $(1+x)^2/(1-x^2)$?
To discover the cancellations in $(1+x)^2/(1-x^2)$, you can expand the numerator and denominator using the FOIL method, and then simplify the resulting expression by combining like terms. This will reveal the cancellations that occur when the expression is fully simplified.
What are the benefits of discovering cancellations in $(1+x)^2/(1-x^2)$?
The benefits of discovering cancellations in $(1+x)^2/(1-x^2)$ include being able to simplify the expression and make it easier to work with, as well as gaining a better understanding of the underlying mathematical principles involved.
Are there any special cases or exceptions when discovering cancellations in $(1+x)^2/(1-x^2)$?
Yes, there are special cases and exceptions to be aware of when discovering cancellations in $(1+x)^2/(1-x^2)$. For example, if x equals 1 or -1, the expression becomes undefined, and if x equals 0, the expression simplifies to 1.
How can discovering cancellations in $(1+x)^2/(1-x^2)$ be applied in real-world situations?
The concept of discovering cancellations in $(1+x)^2/(1-x^2)$ can be applied in various real-world situations, such as in economics, physics, and engineering. It can help in simplifying complex mathematical models and equations, making them easier to analyze and solve.
9K
