Discovery of how to measure wavelength absorption lines
In summary, Johannas Fraunhofer was the first person to discover how to measure the wavelength of absorption lines in the solar or stellar spectra and he did this using a method called diffraction spectroscopy.
Ava_Seven
who was the first person to discover how to measure the wavelength of
absorption lines in the solar or stellar spectra and what method was used?
Astronomy news on Phys.org
Simon Bridge said:
Have you tried entering "discovery of solar absorbtion lines" into google?
https://en.wikipedia.org/wiki/Fraunhofer_lines
I understand that Fraunhofer's measured wavelengths of spectral lines and that he had scribed a diffraction granting with 50000 grooves per inch and had used it for that purpose, getting results for the sodium doublet close to modern values. Regarding his procedure, was he the first or was it Augusti Fresnel or someone else? And what unit did they use?
In 1801 Thomas Young used his experiments with double slits to measure wavelengths of the seven rainbow 'colours' described by Newton and got respectable results. Still don't know the units though.
did you actually read the Wiki link given to you ?
it answered your Q
there is no mention of Augusti Fresnel being involved with emission/absorption lines discovery either in that link or in the wiki entry for Augusti Fresnel
D
it answered your Q
D
Yes I did read the link. No need to be rude. This is a debate/discussion in one of my classes, and the question is generate thought beyond Wiki. Just because Wiki doesn't mention it, doesn't mean those people mentioned didn't do what was said.
wasn't being rude :smile:
your response hinted that you didn't read the link or do any further study
that last bit which is particularly encouraged here on PF
The wiki link told you the name of the person that first noticed the dark bands in the spectrum
but you didn't bother to mention that name, rather went on to other names that weren't in the link
This is vital information you left out.
It's odd to find that you are asked to go beyond wikipedia for a question that is completely answered within wikipedia ...
The questions were:
absorption lines in the solar or stellar spectra...
Johannas Fraunhofer
.. and what method was used?
Further questions were:
Fraunhofer was first. Since you read the link, you ready the bit right at the start that said:
In 1814, Fraunhofer independently rediscovered the lines and began a systematic study and careful measurement of the wavelength of these features.
... under "Discovery". I suppose it does not actually state in so many words that Frounhofer was first, but it also does not put any others before him.
You can use this information to refine your googling to confirm the result if you want to be absolutely sure.
You can also look up the references wikipedia supplies for this information or use the titles as clues for further google searches:
  1. Hearnshaw, J.B. (1986). The analysis of starlight. Cambridge: Cambridge University Press. p. 27. ISBN 0-521-39916-5.
  2. Joseph Fraunhofer (1814 - 1815) "Bestimmung des Brechungs- und des Farben-Zerstreuungs - Vermögens verschiedener Glasarten, in Bezug auf die Vervollkommnung achromatischer Fernröhre" (Determination of the refractive and color-dispersing power of different types of glass, in relation to the improvement of achromatic telescopes), Denkschriften der Königlichen Akademie der Wissenschaften zu München (Memoirs of the Royal Academy of Sciences in Munich), 5: 193-226; see especially pages 202-205 and the plate following page 226.
From the sounds of things - this is what the exercise is all about. "Going beyond wiki" does not usually mean "ask someone else"... rather you should do your own research. We can point you in the right direction but you have to to the work yourself.
The inch.
Also inches ... Young developed the technique of diffraction spectroscopy used by Fresnel and others ... Fresnel has nothing to do with the question in post #1.
But if you want to be sure, you can use google to look for references to these people making wavelength measurements of the dark lines in the solar spectrum.
What sort of search term could you use?[/quote][/quote]
Related to Discovery of how to measure wavelength absorption lines
1. What are wavelength absorption lines?
Wavelength absorption lines are dark lines that appear in the spectrum of a star or other astronomical object. They are created when light from the object passes through a cooler gas, causing specific wavelengths of light to be absorbed by the gas atoms. This creates a pattern of dark lines in the spectrum, which can be used to identify the elements present in the gas and their relative abundances.
2. How were scientists able to discover how to measure wavelength absorption lines?
The discovery of how to measure wavelength absorption lines can be attributed to several scientists, including Fraunhofer, Kirchhoff, and Bunsen. In the early 19th century, Fraunhofer observed dark lines in the spectrum of the sun and hypothesized that they were caused by elements in the sun's atmosphere. Kirchhoff and Bunsen later developed the spectroscope, a tool used to study the spectrum of light, which allowed them to measure and identify the specific wavelengths of the absorption lines.
3. What is the significance of being able to measure wavelength absorption lines?
The ability to measure wavelength absorption lines has had a profound impact on the field of astronomy. It has allowed scientists to identify the chemical composition of stars and other astronomical objects, providing valuable insights into the formation and evolution of the universe. It has also been used to study the motion of stars and galaxies, as well as to identify the presence of exoplanets.
4. What techniques are used to measure wavelength absorption lines?
There are several techniques used to measure wavelength absorption lines, including spectroscopy, interferometry, and Doppler imaging. Spectroscopy involves analyzing the spectrum of light from an object and measuring the specific wavelengths and intensities of the absorption lines. Interferometry uses the interference of light waves to measure the physical properties of an object, such as its size and shape. Doppler imaging uses the Doppler effect to measure the motion of an object, which can be used to study the presence of absorption lines.
5. How have advancements in technology improved the measurement of wavelength absorption lines?
Advancements in technology have greatly improved the measurement of wavelength absorption lines. The development of more precise spectrometers and telescopes has allowed for more accurate and detailed measurements of the absorption lines. Techniques such as adaptive optics and interferometry have also improved our ability to study the spectra of distant objects. Additionally, the use of computer algorithms and data analysis techniques has made it possible to quickly and accurately analyze large amounts of spectral data.
  • Astronomy and Astrophysics
