Discrete Fourier series derivation
In summary, a Discrete Fourier series is a mathematical representation of a periodic function using complex exponential functions. It is derived by applying the Fourier transform to a discrete-time signal, and key equations such as the Fourier transform equation and complex exponential function are used in the derivation. This series has many applications in fields like signal processing and data analysis, but it also has limitations in accurately representing non-periodic signals and being sensitive to noise and sampling rate. These limitations can be addressed through more advanced techniques such as the discrete Fourier transform and the fast Fourier transform.
kidsasd987
143
Hello,
*please refer to the table above.
I started from x(n)=x(n*Ts)=x(t)*delta(t-nTs),
how can we have finite terms for discrete time F.S
can anyone provide me a derivation or proof for Discrete F.S.?
Mathematics news on Phys.org
Think about how you would numerically integrate with the rectangle method. What would the sum look like?
Related to Discrete Fourier series derivation
1. What is a Discrete Fourier series?
A Discrete Fourier series is a mathematical representation of a periodic function in terms of a sum of complex exponential functions. It is a useful tool for analyzing and visualizing the frequency components of a signal or waveform.
2. How is a Discrete Fourier series derived?
A Discrete Fourier series is derived by applying the Fourier transform to a discrete-time signal, which results in a set of complex coefficients representing the frequency components of the signal. This process involves decomposing a signal into its constituent frequencies and their corresponding amplitudes and phases.
3. What are the key equations used in the derivation of a Discrete Fourier series?
The key equations used in the derivation of a Discrete Fourier series include the Fourier transform equation, the inverse Fourier transform equation, and the complex exponential function. These equations are used to represent the signal in the time and frequency domains and to calculate the coefficients of the Fourier series.
4. What are the applications of Discrete Fourier series?
Discrete Fourier series have a wide range of applications in fields such as signal processing, image processing, communication systems, and data analysis. They are used for filtering, compression, noise reduction, and frequency analysis of signals.
5. What are the limitations of Discrete Fourier series?
Discrete Fourier series have some limitations, including their ability to accurately represent non-periodic signals, their sensitivity to noise and sampling rate, and the trade-off between time and frequency resolution. These limitations can be addressed by using more advanced techniques such as the discrete Fourier transform and the fast Fourier transform.
