MHB Discrete Probability Distribution Tables Skills
The discussion focuses on constructing discrete probability distribution tables for a fair six-sided die and analyzing results from a dice simulator. In Part I, participants are tasked with calculating the mean, variance, and standard deviation for the theoretical probabilities of the die. Part II involves creating a distribution table from simulated rolls and performing similar calculations. The comparison reveals minor differences between classical and empirical probabilities, with the largest discrepancy being -0.05 for the value of 1, attributed to the small sample size in the simulation. Overall, the empirical results closely align with theoretical expectations, indicating the simulator's accuracy.
drumsticksss
A problem i made up for some of my friends who need help with discrete distributions tables. Can you do it?
Dice Generator
Part I:
1. Construct a discrete probability distribution table for a fair six-sided dice. (Round according to example)
2. Calculate the mean, variance, and standard deviation based on the probability distribution.
Part II
A dice simulator was used to “roll” sixty six-sided dice. The results are provided below.
2 4 2 4 3 1
4 3 3 1 5 5
6 2 2 1 1 4
4 4 3 1 5 6
1 2 3 2 5 2
1 4 1 5 1 6
5 4 2 3 2 4
6 4 1 4 5 1
3 6 3 3 4 1
6 6 2 1 2 3
1. Construct a discrete probability distribution table based on the data from the simulator. (Round according to example)
2. Calculate the mean, variance, and standard deviation based on the data.
3. Compare the classical probabilities from Part I with the empirical probabilities from Part II. What are the differences in the probabilities for each possible value? Make a table displaying the differences.
Part Ix p(x) x*p(x) x (x-µ)2 (x-µ)2*p(x)
1 0.1667 0.1667 -2.5007 6.2535 1.042
∑x*p(x) = ∑(x-µ)2*p(x)=Part II
x p(x) x*p(x) x-µ (x-µ)2 (x-µ)2*p(x)
1 0.2167 0.2167 -2.1671 4.6963 1.018
∑x*p(x)= ∑(x-µ)2*p(x)=Differences:
x Classical (Part I) Empirical (PartII) Differences
1 0.1667 0.2167 -0.05
Mathematics news on Phys.org
∑p(x)= ∑p(x)=
The differences in probabilities between the classical and empirical data are small, with the largest difference being -0.05 for the value of 1. This could be due to the small sample size in Part II compared to the theoretical probabilities calculated in Part I. However, overall, the empirical probabilities are close to the theoretical probabilities, indicating that the dice simulator is producing fairly accurate results.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
