- 5,199
- 38
I'm reading that if you have a complex exponential exp(iω0n) where n is in the set of integers, then unlike for the case of a continuous independent variable, the set of complex exponentials that is harmonically-related to this one is finite. I.e. there is only a finite number of distinct complex exponentials that have frequencies that are integer multiples of the fundamental frequency ω0. This is because if the frequency differs from the fundamental by 2π: then:
exp[i(ω0+2π)n] = exp(i2πn)exp(iω0n) = exp(iω0n).
Then the book I'm reading gives an example figure in which a progression of discrete cosines is plotted, and pairs of them with different frequencies look identical. There is one with frequency π/8 that looks exactly the same as another with frequency 15π/8. But I would have thought that the next identical one should have frequency 17π/8, since that differs from the original by 2π. At first I thought it was a typo in the book, but when I tried plotting them myself, I found that the sequence with frequency 15π/8 is indeed identical to the one with frequency π/8. I cannot understand why this is.
EDIT: I think it might be because for cosine, if:
ω0 = π/8
then
15π/8 = π/8 + 16π/8 - 2π/8
= ω0 + 2π - 2ω0
= -ω0 + 2π
= -(ω0 - 2π)
and a cosine with a frequency given by the above is ALSO the same as cos(ω0n). Is THAT the reason? If so, then I have figured it out, and you can delete this thread.
ω0 = π/8
then
= ω0 + 2π - 2ω0
= -ω0 + 2π
= -(ω0 - 2π)
