Discussing the Convergence of a Series: Get My Opinion!
The discussion centers on the convergence of a series represented by the ratio (n^2 + 3n + 1)/(n^2 + 5n + 7). The initial claim suggests it can be treated as a geometric series, but others argue that this comparison is invalid due to the nature of the function involved. To analyze convergence, it is recommended to evaluate the limit of (n^2 + 3n + 1)/(n^2 + 5n + 7) raised to the power of n^2, which has an indeterminate form. Using logarithms and L'Hopital's Rule is suggested as a method to resolve this limit. Ultimately, establishing that the limit does not approach zero indicates that the series diverges.
Amaelle
studying the convergence of a serie (look at the image)
geometric serie, convergence
Good day
I want to study the connvergence of this serie
I already have the solution but I want to discuss my approach and get your opinion about it
it s clear that n^2+5n+7>n^2+3n+1 so 0<(n^2+3n+1)/(n^2+5n+7)<1 so we can consider this as a geometric serie that converge?
many thanks in advance
You can't compare to a geometric series; you have a function of n raised to a power which depends on n. That is similar to <br /> \left(1 - \frac 1n\right)^{n} \to e^{-1} &gt; 0. For that reason \sum_{n=1}^\infty \left(1 - \frac1n\right)^n does not converge.
I would write <br /> \frac{n^2 + 3n + 1}{n^2 + 5n +7} = 1 - \frac{2n + 6}{n^2 + 5n +7} and take logs.
Amaelle said:
Homework Statement:: studying the convergence of a serie (look at the image)
Relevant Equations:: geometric serie, convergence
Good day
If you can establish the fact that ##\lim_{n \to \infty}\left( \frac{n^2 + 3n + 1}{n^2 + 5n + 7}\right)^{n^2} \ne 0##, then you can conclude that the series diverges. This limit has the indeterminate form ##[1^\infty]##, so the best way of determining the limit is by the use of logarithms, and getting it to a form in which L'Hopital's Rule can be applied.
thanks you so much!
thanks so much!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
