Dispersion of rightward steps in 1-D random walks
  • Thread starter Thread starter f3sicA_A
    Random walk
The discussion centers on understanding why the quantity ##\overline{(\Delta n_1)^2}## is quadratic in displacement within the context of a 1-D random walk. The calculations show that ##\overline{(\Delta n_1)^2} = Npq##, where ##N## is the total number of steps, and ##p## and ##q## are the probabilities of moving right and left, respectively. The confusion arises from the relationship between this quantity and the displacement ##m = n_1 - n_2##, as well as the interpretation of the quadratic nature of ##\overline{(\Delta n_1)^2}##. The discussion suggests that the statement about quadratic dependence may not be essential to understanding the rest of the material, as the subsequent concepts about relative width of the distribution still hold. Overall, clarity on the quadratic relationship remains a point of inquiry.
f3sicA_A
What is the relation between the dispersion of the rightward steps (##\overline{(\Delta n_1)^2}##) and the displacement of the random walker in a simple 1-D random walk?
$$\overline{(\Delta n_1)^2}=Npq$$
$$m=n_1-n_2$$
I am currently going through the first chapter of Fundamentals of Statistical and Thermal Physics by F. Reif which is on random walks, various mean values, etc. and specifically unit 1.4 mentions "The quantity ##\overline{(\Delta n_1)^2}## is quadratic in the displacement." This is with reference to a simple 1-D random walk where the probability of going to the right is ##p## and the probability of going to the left is ##q\equiv1-p##, where ##n_1## is the number of steps taken to the right and ##n_2## is the number of steps taken to the left, such that ##n_1+n_2\equiv N## is the total number of steps taken.
I am not able to verify as to why ##\overline{(\Delta n_1)^2}## must be quadratic in displacement, ##m=n_1-n_2## (the rightward displacement in units of step length ##l##), and I am not sure how to approach this problem. One thing we have shown just before this statement is:
$$\overline{(\Delta n_1)^2}\equiv\overline{(n_1-\overline{n_1})^2}$$
$$\implies\overline{(\Delta n_1)^2}=\overline{n_1^2-2n_1\overline{n_1}+(\overline{n_1})^2}$$
$$=\overline{n_1^2}-\overline{n_1}^2$$
where we have:
$$\overline{n_1}=\sum_{n_1=1}^{N}P(n_1)n_1$$
$$=\sum_{n_1=1}^{N}\frac{N!}{n_1!(N-n_1)!}p^{n_1}q^{N-n_1}n_1$$
here we have ##n_1p^{n_1}=p\partial {\left(p^{n_1}\right)}/\partial p##, so:
$$\overline{n_1}=\sum_{n_1=1}^{N}\frac{N!}{n_1!(N-n_1)!}\left[p\frac{\partial\left(p^{n_1}\right)}{\partial p}\right]q^{N-n_1}$$
$$=p\frac{\partial}{\partial p}\sum_{n_1=1}^{N}\frac{N!}{n_1!(N-n_1)!}p^{n_1}q^{N-n_1}$$
$$=p\frac{\partial(p+q)^{N}}{\partial p}$$
$$=pN(p+q)^{N-1}$$
and since we have $p+q=1$, in our case, ##\overline{n_1}=Np##. Similarly, we can follow a similar procedure to show that ##\overline{n_1^2}=\overline{n_1}^2+Npq##, and hence showing that:
However, this does not convey to me the idea that ##\overline{(\Delta n_1)^2}## must be quadratic in ##m##, how should I start attempting this problem?
I don’t even know what that statement means.
##\overline{(\Delta n_1)^2}## is a characteristic of the distribution, whereas the displacement, m, is a single value of a random variable.
Is there any ensuing text that clarifies it?
This is the exact paragraph from unit 1.4 of the book:
The quantity ##\overline{(\Delta n_1)^2}## is quadratic in the displacement. Its square root, i.e., the rms (root-mean-square) deviation ##\Delta^*n_1\equiv[\overline{(\Delta n_1)^2}]^{\frac{1}{2}}##, is a linear measure of the width of the range over which ##n_1## is distributed.
Before this paragraph is the proof for ##\overline{(\Delta n_1)^2}=Npq## and after this it talks about ##\Delta^*n_1/\overline{n_1}## being a good measure of relative width of the distribution.
What if you simply ignore the statement that is bothering you/us? Does the rest make sense without it?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
