Displacement of a voigt model and a mass in series
In summary, the problem involves a Voigt model in series with a mass, with an external force exciting the system. The equations F = mx'', F = kx, and F = ηx' are used to solve for the displacement of the system. A solution in the form of a*cos(ωt) + b*sin(ωt) is found using the method of undetermined coefficients, and then combined with the general solution to get the final form without the exponential term.
jk1
A Voigt model in series with a mass is given (so Wall: (mass and damper in parallel) -- mass -- Force ---> ) with a force, F = Fo*cos(ωt) exciting/driving the system.
Givens: Spring constant: K, Viscous constant: η, Mass element: m
Find a solution for established harmonic oscillations in the form a*cos(ωt) + b*sin(ωt).
F = mx''
F = kx
F = ηx'
Let x1 be the displacement of the system (I know the displacement will be the same on the damper and the spring - I don't see how the mass can have it's own displacement, so I'm assuming it
I labeled the forces on the spring and the damper both F1 and F2 respectively, and labeled the force on the mass F3.
F1 + F2 = F3 = Fo*cos(ωt)
I set kx + ηx' = Fo*cos(ωt) and solved the differential equation and got:
x(t) = Ae^(-t*k/η) + Fo*((k * cos(ωt) + η * ω * sin(ωt)) / (η^2 * ω^2 + k^2))
Then I solved using the initial condition x(0) = 0 because the voigt system shouldn't move instantaneously, and the mass shouldn't move unless the voigt model does.
A = -Fo(k / (η^2 * ω^2 + k))
But as you can see, there's an exponential term in my answer and that's not in the final form desired.
I tried finding a different differential equation via mx'' = kx + ηx' = Fo*cos(ωt) but I'm not having much luck - I'm pretty sure I need to have the forcing function involved or it won't work (so I can't just solve mx'' - ηx' -kx = 0).
Any suggestions?
Hello,
Your approach seems to be on the right track. One suggestion I have is to consider the equation mx'' + ηx' + kx = Fo*cos(ωt), which includes the mass element in the equation. This is because the mass will also experience a force from the spring and damper, not just the force from the external force.
Next, you can use the method of undetermined coefficients to solve for the particular solution. This involves assuming a solution in the form of a*cos(ωt) + b*sin(ωt) and then plugging it into the equation to solve for a and b.
Once you have the particular solution, you can combine it with the general solution you already found to get the final form. This should give you an answer without the exponential term.
Hope this helps!
FAQ: Displacement of a voigt model and a mass in series
What is the Voigt model and how does it relate to displacement?
The Voigt model is a mathematical model that describes the behavior of a viscoelastic material, such as a spring and dashpot in series. It relates to displacement by predicting the amount of displacement that occurs when a force is applied to the material.
How does a mass in series affect the displacement in a Voigt model?
A mass in series with a Voigt model adds an additional element of inertia to the system, which causes a delay or lag in the response of the material to the applied force. This results in a different displacement behavior compared to a Voigt model without a mass.
What is the relationship between stiffness and displacement in a Voigt model?
In a Voigt model, stiffness is directly proportional to displacement. This means that as the stiffness of the material increases, the displacement in response to a given force will also increase.
How does the frequency of the applied force affect the displacement in a Voigt model?
In a Voigt model, the displacement is inversely proportional to the frequency of the applied force. This means that as the frequency of the force increases, the displacement decreases.
Can a Voigt model with a mass in series accurately predict the displacement of a real-world material?
While a Voigt model with a mass in series can provide a good approximation of the displacement behavior of some materials, it may not accurately predict the behavior of all real-world materials. Factors such as temperature, loading rate, and material properties can affect the accuracy of the model's predictions.
