oy_katet
- 3
In an oscilloscope, an electron is accelerated from rest through a voltage of 1.14x103 V. It then passes through deflecting plates 2.00 cm apart, across which there is a voltage of 412 V. Its velocity when it enters the plates is perpendicular to the electric field of the plates. When the electron leaves the plates, what distance will it have moved toward the positive plate? The length of the plates are 4.00 cm.
The answer is 7.23x10-3 m
Givens:
vi= 0
Va= 1.14x103 V
Vd= 412 V
length of plate = 4 cm = 0.04 m
d= 2 cm= 0.02 m
Equations:
1/2mv2= Vaq
t=length of plate/v
E=Vd/d
F= Eq
a= F/m
x=1/2at2
So, because it's an electron
q= 1.6x10-19
m= 9.11x10-31
Using the above equations and plugging in the givens, I've gotten:
v= 2.001x107 m/s
t=1.0x10-9 s
E= 20600 v/m
F= 3.296x10-15 N
a= 3.618x1015 m/s2
x= 1.809x10-3 m
which is not the right answer :( I'm not very good at physics so I'm having a hard time figuring out what I'm doing wrong.
