B Displacement of Hanging Mass - Simple Pulley System
The discussion centers on understanding the displacement of a hanging mass in a simple pulley system when the left cord is pulled. The user initially struggles to connect the change in length of the cord, denoted as ##l_x##, to the expected movement of the mass, which should be ##\frac{\delta}{2}##. A clarification is provided that differentiates between the distance pulled up, ##\delta##, and the resultant change in the mass's height. By introducing a fixed coordinate system with a reference point from the ceiling, the relationship between the lengths becomes clearer, allowing for the correct interpretation of how the mass moves. Ultimately, defining a fixed coordinate system resolves the confusion regarding the displacement calculations.
erobz
I'm having some kind of mental block.
If I extend ##l_x## by ##\delta## ,I expect the hanging mass to move ##\frac{ \delta}{2}##.
I can't figure out how this is the case from the constraint:
$$ l_x+l_1=C $$
##C## is an arbitrary length
I keep getting that ##l_1## changes by ##\delta##, but that must mean the height of the mass changes by ##\delta##...
:oldgrumpy:
I suspect you need to differentiate between the distance you pull the left hand cord up, ##\delta##, and the increase in distance from that point to the pulley, ##\frac \delta 2##.
Call the distance of the left end of the cord from the ceiling ##y##. Then ##l_x=l_1-y## and ##l_x=C-l_1## from the constraint given by the fixed length of the entire cord. Then you can eliminate the somewhat inconvenient quantity ##l_1## in favor of ##y## which has a well defined meaning of a coordinate, i.e., it's a length measured from a fixed reference point (the ceiling):
$$C-l_1=l_1-y \; \Rightarrow \; L_1=\frac{1}{2}(C+y).$$
So if you change ##y## by ##\delta## (which is the same as changing ##l_x## by ##-\delta##) ##L_1## (the distance of the pulley from the ceiling) changes by ##\delta/2##.
Likes topsquark and erobz
The addition of the coordinate ##y## and the weirdness seems to vanish right in front of my eyes. Amazing!
My key failure was that I had not defined a fixed coordinate system. I basically was trying to measure distances relative the datum at the center of the pulley...a transformation not so obvious to me.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
