Displacement vector on a watch?
In summary: L to get V1=2jThen at 8:20 am, i (2 sin 2pi ((1/3)/12) + j ((2 cos 2pi ((1/3)/12)), to have V2 = .347i + 1.96j.So V2-V1 would be (.347i + 1.96j) - 2j to get the answer of the coordinates (.347, -.04). In summary, the displacement vector of the tip of the minute hand from 8:00 am to 8:20 am is (.347, -.04) cm. This can
skysunsand
39
The minute hand on a watch is 2.0cm in length. What is the displacement vector of the tip of the minute hand from 8:00 am to 8:20 am?
It wants it in x and y components.
I found this equation online- i(L sin 2pi(T/12)) + j ((L cos 2pi (T/12))
where L is length, T is time in hours
Tried plugging my numbers into the equation- 2 for L, and 1/3 for T, since it's 20 minutes. And then each "side" (sin or cos) would be the components of the vector. But not so, something is obviously not correct. Help please? Physics is terribly discouraging. :(
I highlighted part of your OP.
To the rest of us there not something obviously incorrect, as you have not shown even your calculated answers, let alone your working [what you were substituting in where] ??
It may have been as simple as having your calculator set to radians not degrees, or vice-versa.
Position vector at 8.00 am is V1 = L( 0 + j)
Position vector at 8.20 am is V2 = i(L sin 2pi(T/12)) + j ((L cos 2pi (T/12))
So the displacement vector Vd = V2- V1
Oh, my fault. Allow me to further clarify-
1. Homework Statement
2. Homework Equations
3. The Attempt at a Solution
i (2 sin 2pi ((1/3)/12) + j((2 cos 2pi ((1/3)/12)) and put it into my calculator to get 2.00 as my final answer for the whole thing. My calculator is set correctly, that I do know.
Then in thinking each of them were split, for the sin side I got 0.005 and for the cos side I got 1.99.
at 8:00 am, plugged in 2 for L to get V1=2j
Then at 8:20 am, i (2 sin 2pi ((1/3)/12) + j ((2 cos 2pi ((1/3)/12)), to have V2 = .005i + 1.99j.
So V2-V1 would be (.005i+1.99j)-(2j) to get the answer of the coordinates (.005,-.001), right?
Looks more like the tip of a 2cm hour hand!
Try substituting T = 1 and see if the hand is back where it started, because a minute hand certainly is.
For T=1
at 8am, 2 for L, 1 for T=
V1=2j
V2= i(2sin2pi(1/12)) + j(2cos2pi(1/12)) = 0.016 i + 1.999j
Then V2-V1 = 0.016i + 1.999j -2j still gets me (0.016i-.001j)
For T=1
V1=2j
You said your calculator was set to the appropriate radians or degrees.
Perhaps you don't realize whether the following is in radians or degrees
2sin2pi(1/12)
I'll give you a hint - the value of 2sin2pi(1/12) is 1.0
2sin2pi(1/12)
Oh. Well then it was a calculator problem...
Then I should go back to plugging in 1/3 for my T and then I should have the correct answer, right?
Those numbers are still wrong?
I think the formula is not the formula for the end of a minute hand.
use that formula to find out the displacement from 8:00 until 9:00 - because the answer had better be 0EDIT: and not approximately zero; exactly zero
at 8:20, the j component of the tip of the minute hand is negative for a start ?
I reckon it is 1.7i - j, or more accurately sqrt(3)i - j
The answer was 1.73,-3.00. Why??
even you subtracted 2j from your (incorrect) displacement vector. why did you do that?
In the problem the displacement vector of the tip of the minute hand from 8:00 am to 8:20 am is required.
If OA be the position vector at 8.00 am and OB be the position vector at 8.20 am, then the displacement vector is AB = OB - OA.
Now that you know the solution, and how it was found: I offer the following:
Once a "random" formula you found on-line resulted in an incorrect answer you should have been shown something.
Either this is not the formula you thought it was [you should now know it wasn't: this formula was for an hour hand], or you don't know how to use the formula.
How you should have solved this problem.
Draw a clock face with two minute hands, one at 8:00 and one for 8:20 [don't bother drawing the hour hands - and in case you are wondering this hour-hand-less clock would show the same thing if you were drawing 10:00 and 10:20]
What is the angle between the two hands ?
Imagine x-y axes drawn over the clock fact. The co-ordinates of the end of the 8:00 hand are (0,2)
To get to 8:20, we rotate 120 degrees.
The new x-coordinate is simple 2*sin120 = 1.732
The new y-coordinate is 2*cos120 = -1
to get from (0,2) to (1.732,-1) you move 1.732 right (in the x direction) and 3 units down (-3 in the y - direction)
with the 120o angle involved, you don't even need sine and cosine functions, these values relate to the 60-30 or 2,1,root(3) triangle. The hypotenuse [hand] is even two units long so the x and y coordinates are simply 1 and root(3)
That's correct Peter!
Origin at watch's center.
y axis at 8:00 ------> vector V_1 = 0i + 2j.
x axis at 8:15 ----> 15 min. = (1/4)60 min ----> (1/4)360 deg. = 90 deg.
20 min = (1/3)60 min. -----> (1/3)360 deg. = 120 deg.
angle among 8:15 and 8:20 = 120 - 90 = 30 deg (below x).
vector V_2 = 2(cos30i - sin30j) ----> V_2 = sqrt{3}i - j (2 cancel).
By definition,
dV = V_2 - V_1 = (sqrt{3}i - j ) - ( 0i + 2j).
And the answer is:
dV = sqrt{3}i - 3j.
FAQ: Displacement vector on a watch?
What is a displacement vector on a watch?
A displacement vector on a watch is a graphical representation of the distance and direction traveled by the watch's hands. It is typically used to measure the change in position of the watch's hands from one point in time to another.
How is a displacement vector on a watch calculated?
A displacement vector on a watch is calculated by subtracting the initial position of the watch's hand from its final position. It takes into account both the magnitude (distance) and direction of the movement.
What units are used to measure a displacement vector on a watch?
Displacement vectors on a watch are typically measured in units of distance, such as millimeters, centimeters, or inches. However, they can also be measured in units of time, such as seconds or minutes, depending on the scale of the watch's face.
Can a displacement vector on a watch be negative?
Yes, a displacement vector on a watch can be negative. This means that the watch's hand has moved in the opposite direction of its initial position. For example, if a watch hand initially points to the 12 o'clock position and then moves counterclockwise to the 10 o'clock position, the displacement vector would be negative.
How is a displacement vector on a watch useful in scientific research?
Displacement vectors on a watch are useful in scientific research as they can provide precise measurements of time and motion. They can be used to track the speed and acceleration of an object, as well as to calculate the work done by the object over a period of time. They are also important in understanding the concept of displacement and how it relates to the position of an object.
