Displacement with and without friction
In summary, the conversation involves a situation where a person is shot out of a human cannon with a given initial velocity, mass, and maximum constant force. The problem is to find the final velocity and determine the role of friction in this scenario. The attempted solution uses equations for displacement and time, but there is confusion regarding the direction of motion and whether the final velocity being zero means the person hits a wall or fails to make it out of the cannon. Further clarification and a more specific question are needed to properly solve the problem.
jessiegirl121
1. When someone gets shot out of a human cannon with an initial velocity of 15 m/s and they have a mass of 60 kg. Final velocity is 0. Maximum constant force is 3000 N. This is free fall so acceleration is 10 m/s^2. There is no friction. So when you look at my attempt in solution I got the same answer as I did when I did this equation with friction because I did the same steps. So what is different about friction? How can I fix it?
Δ/A=T
D=(Vi*T)=.5 (at^2)
Well I did
15/10=1.5
(15*1.5)+.5(10*1.5^2)= 22.5 +11.25=33.75.
Welcome to PF!
I am bewildered by the question. What is actually going on? Are you shooting horizontally or vertically? When you say "Final velocity is 0." do you mean the person hits a brick wall or that the shot was a fizzle and he didn't make it out the end of the cannon? If he did get shot out and there is no friction, he would only have velocity zero when shot vertically and then only at the maximum height reached. Are we looking for the maximum height here? That is what your calculation applies to, except you have up and down both taken as positive directions in the second equation.
It is so important to provide the exact wording of the question. Simplifications often make a problem impossible to solve.
FAQ: Displacement with and without friction
What is displacement with friction?
Displacement with friction is the change in position of an object from its starting point to its ending point, taking into account the effects of friction on the object's movement.
How is displacement with friction calculated?
Displacement with friction is calculated by subtracting the initial position of the object from its final position. This accounts for any changes in position caused by friction.
What is displacement without friction?
Displacement without friction is the change in position of an object from its starting point to its ending point, not taking into account the effects of friction on the object's movement.
How is displacement without friction calculated?
Displacement without friction is calculated by subtracting the initial position of the object from its final position. This does not account for any changes in position caused by friction.
How does friction affect displacement?
Friction can affect displacement by slowing down or altering the movement of an object, resulting in a difference between the calculated displacement with and without friction. Friction can also cause the object to move in a different direction than intended, leading to a change in displacement.
