Dissipation due to heat conduction
In summary, the dissipation due to heat conduction is represented by the equation D = -k(q∙∇T)/T, where q is the heat flux, k is the coefficient of heat conduction, and T is the absolute temperature. This equation can also be written as k^2(∇^2T)/T, with units of W^2 m^-4 K^-1. In kinetic theory, this term would correspond to Tk∙σ̇, where σ̇ is the volumetric rate of entropy creation. However, it is not commonly used for any practical purposes.
pere.balazs
What is the dissipation due to heat conduction?
[tex] D = -k \frac{\vec q\cdot\nabla T}{T} [/tex]
coefficient of heat conduction and T is the absolut temperature.
What is the physical meaning of this?
Science news on Phys.org
This is a peculiar term. According to Fourier's law of conduction,
[tex]\vec{q}\equiv -k\nabla T\mathrm{,}[/tex]
so
[tex]-k \frac{\vec q\cdot\nabla T}{T}=k^2\frac{\nabla ^2 T}{T}[/tex]
with units of W2 m-4 K-1. In kinetic theory, this would correspond to [itex]Tk\dot{\sigma}[/itex], where [itex]\dot{\sigma}[/itex] is the volumetric rate of entropy creation. To my knowledge, this term isn't used for anything useful; are you certain about it?
The dissipation due to heat conduction refers to the process of heat energy being transferred from a region of higher temperature to a region of lower temperature through the movement of particles. This dissipation is quantified by the D term in the equation, which takes into account the heat flux, or the rate of heat transfer, as well as the temperature gradient, or the difference in temperature between the two regions. The coefficient of heat conduction, k, represents the material's ability to conduct heat and influences the rate of dissipation. The physical meaning of this equation is that it describes the mechanism by which heat is transferred through a material, and how much energy is dissipated in the process.
FAQ: Dissipation due to heat conduction
What is dissipation due to heat conduction?
Dissipation due to heat conduction is the process of heat transfer between two objects or substances in contact with each other. This transfer occurs when there is a temperature difference between the two objects, causing the heat to flow from the hotter object to the cooler object until they reach thermal equilibrium.
How does heat conduction lead to dissipation?
Heat conduction leads to dissipation because as heat is transferred from one object to another, some of the energy is lost to the surroundings in the form of thermal radiation or convection. This results in a decrease in the overall available energy and an increase in the entropy of the system.
What factors affect the rate of dissipation due to heat conduction?
The rate of dissipation due to heat conduction can be affected by several factors, including the temperature difference between the two objects, the thermal conductivity of the materials, the surface area and thickness of the objects, and the presence of any insulating layers.
How is heat conduction different from other forms of heat transfer?
Heat conduction is different from other forms of heat transfer, such as convection and radiation, because it requires direct contact between the two objects or substances. In contrast, convection involves the transfer of heat through the movement of fluids, and radiation involves the transfer of heat through electromagnetic waves.
How can dissipation due to heat conduction be reduced?
Dissipation due to heat conduction can be reduced by minimizing the temperature difference between the two objects, using materials with low thermal conductivity, and adding insulation to reduce heat flow. Additionally, increasing the surface area of the objects can also help to reduce dissipation by increasing the contact area for heat transfer.
