Dissolving Event Horizon w/Charged & Rotating BH
In summary: So the hole gets bigger and the event horizon becomes wider, but eventually the electrons run out of energy and the hole becomes naked again.
arusse02
24
I saw a fascinating video from PBS space time about dissolving an event horizon. See here for reference:
The video addresses rotating kerr black holes and charged black holes, but doesn't talk about the combination of rotation and charge. So what happens when you spin up the black hole as much as possible so that its an extremel black hole, and then on top of that you start adding electrons with such a trajectory that it still contributes angular momentum? Does the outward pressure of the black hole rotation and the charge combine, thus letting us easily produce a naked singularity? Or is there some effect such that adding electrons to a rotating kerr black hole would somehow expand the event horizon just enough to prevent a naked singularity? Thanks.
This is a pop science video and is not a good source for learning the actual physics.
Combining rotation and charge doesn't add anything qualitatively new.
Yes. When you work out the details, it turns out that however you try to add angular momentum or charge to a near-extremal hole, you have to add enough mass along with it to keep the hole from becoming super-extremal (which is what would be required to form a naked singularity).
The electrons have mass, and need kinetic energy if they are going to contribute angular momentum. That mass and energy contribute to the mass of the hole at least as much as is necessary to keep it from becoming super-extremal. And as you add electrons and the black hole becomes charged you have to give the electrons more energy to get them to the event horizon, since like charges repel.
Related to Dissolving Event Horizon w/Charged & Rotating BH
1. What is a Dissolving Event Horizon?
A Dissolving Event Horizon is a theoretical concept in physics that refers to the boundary around a black hole beyond which nothing, including light, can escape. It is also known as the "point of no return".
2. What is a Charged and Rotating Black Hole?
A Charged and Rotating Black Hole, also known as a Kerr-Newman black hole, is a type of black hole that possesses both electric charge and angular momentum. This type of black hole is described by the Kerr-Newman metric in general relativity.
3. How does a Charged and Rotating Black Hole affect the Dissolving Event Horizon?
The presence of charge and rotation in a black hole can significantly affect the properties of the Dissolving Event Horizon. For example, a charged black hole has an electric field that can alter the shape and size of the event horizon, while rotation can cause the event horizon to become oblate (flattened at the poles) instead of spherical.
4. What are the implications of Dissolving Event Horizon w/Charged & Rotating BH for our understanding of black holes?
The concept of Dissolving Event Horizon w/Charged & Rotating BH has important implications for our understanding of black holes. It challenges the traditional notion of a black hole having a fixed event horizon, as the presence of charge and rotation can alter its properties. This concept also has implications for the study of black hole thermodynamics and the information paradox.
5. Can Dissolving Event Horizon w/Charged & Rotating BH be observed or tested?
Currently, there is no direct observational evidence for Dissolving Event Horizon w/Charged & Rotating BH. However, scientists are studying the effects of charge and rotation on black holes through simulations and theoretical calculations. In the future, advancements in technology may allow us to observe and test this concept.
