Distance and displacement confusion
In summary, part (a) is done correctly, but part (b) is incorrect because the acceleration is not constant.
Ab17
99
1. The problem statement, all variables and given/known
Two objects move with initial velocity -8.00 m/s xfinal velocity 16.0 m/s xand constant accelerations. (a) The first object has displacement 20.0 m. Find its accelera- tion. (b) The second object travels a total distance of 22.0 m. Find its acceleration. x
2. Homework Equations
Vf^2=vi^2 + 2ax
(a) (-8)^2 = (16)^2 + 2a(22)
a = 4.36m/s
(b) 0 = (-8)^2+ 2a(11)
a= -2.91m/s2
(16)^2= (0)^2 + 2a(11)
a= 0.73m/s2
a = -2.91 +0.73
a= -2.18m/s2
Is this how it is done?
Vf^2=vi^2 + 2ax
a = 4.36m/s
You've got your Vf and Vi mixed up...and displacement is 20 m , not 22 m...what's the direction of the acceleration?
a= -2.91m/s2
a= 0.73m/s2
a = -2.91 +0.73
a= -2.18m/s2
the acceleration is constant, so you can't have 2 values. You incorrectly assumed it goes 11 m each way. The distance it travels from rest varies as the square of the final speed.
Can you please explain fully how part b is done I don't understand
For part b, consider splitting the trajectory into two parts. One as the object slows from -8 m/s to zero. And one as the object accelerates from zero to +16m/s. How long does the second part last compared to the first?
Thats what I done. I got two accelerations
See post #3. You split it in half. Why half? You are told that the acceleration is constant. That information allows you to determine what fraction of the total time elapses in each part.
The question asks for acceleration and not time
Can you please explain by an example. I don't understand what you saying
The problem says that the acceleration, whatever it is, is constant. So take it as a constant and call it "a".
How much time elapses while the object slows down from -8 m/s to 0 m/s?
How much time elapses while the object speeds up from 0 m/s to 16 m/s?
Express both answers in terms of a.
Edit: let me expound a bit on the strategy that I have in mind...
In general terms, we are looking at an object that is moving first to the left and then to the right under a constant rightward acceleration.
We want to know the acceleration, a. We know the starting velocity, ending velocity, total distance covered and the fact that the acceleration is constant. Ideally we could find a single equation involving starting velocity, ending velocity, distance moved along the path and acceleration and solve for acceleration.
We have an equation that relates starting velocity, ending velocity, displacement from start to end and acceleration. But that equation does not help much because the path folds back along itself. The distance moved along the path does not match the displacement from start to end.
If we can split the path into two parts, each of which involves a straight line path that never reverses itself then we can use that displacement equation for each part separately. There are a number of ways to use this general approach. The one I have in mind is...
Working backward, the hope is that we can figure out what fraction of the total distance is covered in the first (or second -- it does not matter which) part of the event. If we knew either one, we'd be in a position to solve for the required acceleration.
How do we determine the fraction of the total distance covered? If we knew the fraction of the total time elapsed for each part, that information might come in handy.
So, what fraction of the total time is required for each part? That motivates the questions I've asked above.
Vf = vi + at
0 = -8 + at
a = 8/t
16= 0 +at
a = 16/t
That does not answer the questions that I posed.
Xf = xi + 1/2(Vf + Vi)t
-11 = 0.5(0 -8)t
t = 2.75s
11 = 0.5 ( 16 + 0)t
t = 1.375s
Those answers are incorrect and are not expressed in terms of "a".
I don't see any other way to relate accleration and time
v = at
Thats what I used In post #11
Post 11 claims that 8 = 16.
I will get the same thing if I use V = at
Let us review...
The answer for the first question is "the elapsed time is 8/a"
The answer for the second question is "the elapsed time is 16/a"
If the acceleration is the same for both phases, what does that say about the elapsed time for both phases?
Time has to be different
Yes. The time has to be different. And the ratio between the two times is what?
8/a and 16/a
That would be 2 to 1. It takes twice as long accelerating to 16 m/s as it does decelerating from 8 m/s.
Now, If the ratio of the times is 2 to 1, what is the ratio of the distances traveled during the two phases?
2 to 1?
Ab17 said:
2 to 1?
If acceleration is fixed and you double the time, what happens to the distance traversed?
X= 1/2axt^2
So what is the ratio of the two distances?
Related to Distance and displacement confusion
1. What is the difference between distance and displacement?
Distance refers to the total length covered by an object in its motion, while displacement is the shortest distance between the initial and final positions of an object.
2. How are distance and displacement related?
Distance and displacement are related in that they both involve measuring the movement of an object, but they differ in their measurements. Distance is a scalar quantity, while displacement is a vector quantity.
3. Can distance and displacement have the same value?
Yes, it is possible for distance and displacement to have the same value if the object moves in a straight line without changing direction. In this case, the displacement will be equal to the distance.
4. Why is it important to understand the difference between distance and displacement?
Understanding the difference between distance and displacement is important because it helps us accurately describe and measure the motion of objects. It also allows us to calculate other important variables such as speed and velocity.
5. How do you calculate distance and displacement?
Distance can be calculated by adding up all the individual distances traveled during a journey. Displacement can be calculated by finding the difference between the final and initial positions of an object. This can be done using a ruler, measuring tape, or by using mathematical equations such as the Pythagorean theorem.
9K
