Distance between adjacent fringes
  • Thread starter chef99
  • Tags
    Fringes
In summary, a laser with a wavelength of 760nm is directed at a diffraction grating of 1500 lines/cm, located 1.5m from the screen. The calculated distance between adjacent bright fringes is 0.17m.
chef99
75
Light from a laser with a wavelength of 760nm is directed at diffraction grating of 1500 lines/cm. If the diffraction grating is located 15.m from the screen, calculate the distance between adjacent bring fringes.
∆y = L λ/d
Given:
Line density = 1500lines/cm
L = 1.5m
λ = 760nm = 7.6 x10-7m
Required: ∆y
Solution:
d= 1.0cm / 1500lines
d= 6.67 x10-6m∆y = L λ/d
∆y = (1.5m)(7.6 x10-7m) / (6.67 x10-6m)
∆y = 0.1709m
∆y = 1.7 x10-1mTherefore, the distance between adjacent bright fringes is 1.7 x10-1m.
I'm pretty confident with this answer, but I'm not sure if I determined the value of d correctly, (is it always 1.0cm/# of lines?) Also should the final answer be presented as 1.7 x10-1m, or 0.1709m, as it is not a very small number, as is usually the answer (such as 1.7 x10-6). Any feedback would be a big help.
Hi chef,
You say 1.5 m, the problem statement says 15. m ?
All givens are in two digits, so the answer is too: 0.17 m
BvU said:
Hi chef,
Sorry my mistake, it is in fact 1.5m. I just wrote out the problem incorrectly. assuming L= 1.5m, everything else looks good?
Looks good, yes.
It is indeed not a small angle. If you want detail: the proper equation is ## d\sin\theta = n\lambda## and ##y = L\tan\theta\;.\ ## So maxima are at 0, 0.172, 0.351, 0.546, 0.769, 1.041 m from the axis. But the exercise doesn't ask for that kind of detail.
Related to Distance between adjacent fringes
1. What is the distance between adjacent fringes?
The distance between adjacent fringes is the distance between two consecutive bright or dark fringes in a diffraction or interference pattern. It is typically measured in units of length, such as meters or millimeters, and is dependent on the wavelength of the light source and the distance between the source and the screen or detector.
2. How is the distance between adjacent fringes calculated?
The distance between adjacent fringes can be calculated using the formula d = λL/D, where d is the distance between fringes, λ is the wavelength of the light source, L is the distance between the source and the screen or detector, and D is the distance between the slits or diffraction grating. This formula is known as the grating equation and is derived from the principles of diffraction and interference.
3. Does the distance between adjacent fringes change with different light sources?
Yes, the distance between adjacent fringes will change with different light sources. This is because the distance is dependent on the wavelength of the light, and different light sources emit different wavelengths. For example, a red laser will have a different distance between fringes compared to a blue laser, even if the other parameters (distance between source and screen, distance between slits) are the same.
4. Can the distance between adjacent fringes be adjusted?
Yes, the distance between adjacent fringes can be adjusted by changing the parameters in the grating equation. For example, the distance between fringes can be increased by increasing the distance between the source and the screen, or by decreasing the distance between the slits or grating. This allows for control over the diffraction or interference pattern produced by the light source.
5. Why is the distance between adjacent fringes important in diffraction and interference experiments?
The distance between adjacent fringes is important because it provides information about the characteristics of the light source and the medium through which it is passing. By measuring the distance between fringes, scientists can determine the wavelength of the light and the spacing of the slits or grating, which can then be used to study the properties of the medium, such as its optical density or refractive index.
