MHB Distance between Compact Subsets
  • Thread starter Thread starter Sudharaka
    Compact Subsets
Sudharaka
MHB
Hi everyone, :)
Here's a question that I couldn't find the full answer. Any ideas will be greatly appreciated.
Let \((X,\,d)\) be a metric space. Let \(F_1,\,F_2\) be two nonempty compact subsets of \(X\). Prove that, there exists \(x_1\in F_1,\,x_2\in F_2,\) such that,
\[d(x_1,\,x_2)=\mbox{inf}\{d(x,\,y):x\in F_1,\,y\in F_2\}\]
I felt that the compactness of \(F_1\) and \(F_2\) could be brought into the question using the following equivalency. However all my attempts to solve the question weren't successful. :)
Let \((X,\,d)\) be a metric space and \(S\) is a compact subspace of \(X\). Then, any sequence of points in \(S\) has a subsequence which is convergent to a point in \(S\).
Assume that $$F_1\cap F_2=\emptyset$$, otherwise there is nothing to prove.
Let $$D(F_1,F_2)=\delta=\inf\{d(x,y):x\in F_1~\&~y\in F_2\}$$
$$\exists x_1\in F_1~\&~y_1\in F_2$$ such that $$\delta\le d(x_1,y_1)<\delta+1$$
Let $$\epsilon_2=\min\{.5, d(x_1,y_1)\}$$.
$$\exists x_2\in F_1~\&~y_2\in F_2$$ such that $$\delta\le d(x_2,y_2)<\delta+\epsilon_2$$.
Let $$\epsilon_n=\min\{n^{-1}, d(x_{n-1},y_{n-1})\}$$.
$$\exists x_n\in F_1~\&~y_n\in F_2$$ such that $$\delta\le d(x_n,y_n)<\delta+\epsilon_n$$.
Now use compactness to get limits points of the two sequences.
Thank you so much. The thing I missed was to use the right hand side of the inequalities,
\(d(x_1,\, y_1)< \delta \,\cdots ,\, d(x_n,\,y_n)<\delta+\epsilon_n\) and so on. Thanks again for your help, I really appreciate it. :)
But can you please explain why you specifically wanted to use the epsilons? I mean, we know that there exist \(x_1\) and \(y_1\) such that,
\[\delta\leq d(x_1,\,y_1)<\delta+1\]
and \(x_2\) and \(y_2\) such that,
\[\delta\leq d(x_2,\,y_2)<\delta+\frac{1}{2}\]
and generally, \(x_n\) and \(y_n\) such that,
\[\delta\leq d(x_n,\,y_n)<\delta+\frac{1}{n}\]
Using the compactness we can still arrive at the result isn't? :)
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
