Distance between earch and the echo of the Tycho Supernova
In summary: This information can be useful in a debate regarding the potential variation of the speed of light over time, as it provides a reference point for the distance between SN 1572 and the deflection point for the echo.
ragarth
Is there a known distance between Earth and the dust/gas that the light was reflected from for the supernova of SN 1572 (Tycho's supernova)? I need this calculation to be made without adding the distance to SN 1572 to the time between Tycho's observation and now.
Also, what's the angle between SN 1572 and the echo remnant? Found this one, 3.15 degrees
This information would be useful in a debate between myself and someone else, the idea is that if the speed of light has varied within the passed 6,000 years, then the distance between SN 1572 and the deflection point for the echo would be something other than 452 light years.
Astronomy news on Phys.org
Unfortunately, it is not possible to calculate the exact distance between Earth and the dust/gas that the light was reflected from for the supernova of SN 1572 (Tycho's supernova) without adding the distance to SN 1572 to the time between Tycho's observation and now. This is because the speed of light can vary depending on the medium it is travelling through, and we cannot assume an exact constant speed. Furthermore, the exact distance is also affected by the curvature of space-time, which varies with time and location.However, the approximate distance between Earth and the dust/gas that the light was reflected from for the supernova of SN 1572 is estimated to be around 452 light years. This estimate is based on the assumption that the speed of light has been constant over the past 6,000 years, and takes into account the curvature of space-time. The angle between SN 1572 and the echo remnant is 3.15 degrees.
Related to Distance between earch and the echo of the Tycho Supernova
What is the Tycho Supernova and why is it important?
The Tycho Supernova is a supernova that occurred in the Milky Way galaxy in the year 1572. It is important because it was one of the brightest supernovae ever recorded and has provided valuable insights into the life cycle of stars.
How far away is the Tycho Supernova from Earth?
The exact distance between Earth and the Tycho Supernova is not known with certainty. However, estimates suggest that it is between 10,000 and 16,000 light years away.
What is the significance of the distance between Earth and the Tycho Supernova?
The distance between Earth and the Tycho Supernova is significant because it has allowed scientists to study the supernova and its effects in detail. It also provides a benchmark for measuring the distance of other objects in the Milky Way galaxy.
How was the distance between Earth and the Tycho Supernova determined?
The distance between Earth and the Tycho Supernova was determined using various methods, such as parallax measurements, spectroscopy, and the study of the supernova's light curve. These methods involve comparing the brightness and properties of the supernova to known stars and objects in the Milky Way galaxy.
What has the study of the distance between Earth and the Tycho Supernova revealed?
The study of the distance between Earth and the Tycho Supernova has revealed important information about the expansion of the universe, the composition of the Milky Way galaxy, and the processes involved in the death of stars. It has also helped scientists better understand the behavior of supernovae and how they impact their surrounding environments.
  • Astronomy and Astrophysics
32K
